Old 06-15-2011, 08:19 PM   #1
grs
Fuse for cigarette lighter
Can't find the fuse for the lighter. My truck never had a lighter. I installed a outlet for my Garmin GPS. . I found a red hot wire where the lighter would be. The outlet was messed up and it grounded out , and popped the horn fuse. Was the lighter also on the horn fuse. Thanks for any help.
grs is offline   Reply With Quote
Old 06-15-2011, 08:57 PM   #2
cr34t3d_by_d4rkd3n
Re: Fuse for cigarette lighter
16OR-I40 is the wire you are using....
Its possibly factory missed, previous owner removed, who knows, that circuit is crazy, ive followed and clipped, and what not all with these wires on this circuit.... space is tight.
It is capable of charging a gps, brief intervals of use with cig lighter, but i wouldent push it, this line is also the hot to your dome lights, so doors open, lights on, 2 ppl light up, POP! blow a fuse.
I reccomend taking advantage of the spare terminals on your fuse panel, run off an ac circuit, they should be 30a? run a wire off that male, with an inline blade type, 10a if used with cig lighter, 5-7a if just gps
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 06-15-2011, 10:00 PM   #3
grs
Thanks. There is no lighter in the truck, and I think I will not have an interior light bulb. I may have the doors open all day at a car show.
Old 06-16-2011, 08:08 PM   #4
grs
I found out that the lighter is on the same fuse as the horn. Along with a few other things.
Old 06-16-2011, 08:28 PM   #5
grs
I posted info on fuses and there circuits.
Old 06-17-2011, 08:18 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
i've used a rear heater switch to run the dome light
up grounds to the body (gives paasenger control),down is normal ,
but the the door pin wires need to go together before the switch
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-17-2011, 10:20 AM   #7
grs
I like that idea. I may use a toggle switch. Thanks for the idea.
Old 06-17-2011, 10:22 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
just make sure it has an off spot..........
For me i had the switch and the hole there already and removed the heater
John
