06-22-2011, 01:59 PM | #1 |
remote starting - 73 gmc
Hi guys, have a problem starting engine remotely. One problem is the neg battery ground cable is smoking. It is properly grounded to the frame. The engine is not grounded. Am using an acutron remote starter. I don't know why this is happening. The starter has on the batt screw the pos cable , the hot wire from the alternator and the red wire from the alternator plug. These 2 wires are spliced together to a fusible wire. The other wire on the alt plug is the exitor and is connected to the "Ign" screw. Hope this helps. Need assistance. Thanks in advance.
06-22-2011, 10:20 PM | #2 | |
Re: remote starting - 73 gmc
I think the ungrounded engine is your problem. The starter draws a lot of current and it gets it's ground by being bolted to the engine block. So you need the battery ground cable hooked to the engine block (not the frame) to make sure the starter has a good ground. The frame/body ground isn't really important in terms of starting/running the engine. The frame/body ground is only used by things like the lights, heater fan, radio, and such. Last edited by ray_mcavoy; 06-22-2011 at 10:21 PM. |
06-22-2011, 10:26 PM | #3 |
Or a big fat ground from the engine to the same spot on the frame the batt is grounded at
