Old 06-26-2011, 05:51 PM   #1
SamMargritz00
SamMargritz00's Avatar
Question 72 Blazer side panel help
I need some ideas for what to do for the rear side panels of my 72. I had the CST chrome strips that went on the side but they were in rough shape so i dont think im going to use them. The original panels were in horrible condition so i tossed them out. I want them to be somewhat easy to take off and put back on due to the double wall hard top. it would be nice to have it clean the whole way (no holes or anything) Im wanting to get it covered in a leather type material to match my seats. any ideas or pictures will help. thx.
SamMargritz00 is offline   Reply With Quote
Old 06-26-2011, 09:34 PM   #2
NuBomb
NuBomb's Avatar
Re: 72 Blazer side panel help
I have a single-wall top, so I don't have to worry about access, but I did use my chrome strips. Mine were in rough shape so I had them blasted and powdercoated black.
I made mine with diamond plate aluminum, but others have used vinyl and such. Do a search here in the blazer forum and you should see a few.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 06-27-2011, 12:53 PM   #3
SamMargritz00
ive actually seen some pictures on posts here using a spacer of some sort which looks like a good idea, but i have no idea how it would stay fastened.
Old 06-27-2011, 07:09 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
If ease of access is the primary concern, I've seen the hook and loop route used. The one I'm referring to had the panels extend further than normal (all the way to the doors in the front and all the way to the tailgate in the rear) so it had a full strip from top to botton. If you have the risers on the sides, you can put a patches there. As for the top, it's still try to use the chrome strips (after getting them refinished) to keep them securely in place.
If I ever find a set of risers, I'm going to attempt this route...as long as I don't decide to toss some speakers in it, then it'll probably have to be more secure.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 06-28-2011, 11:20 AM   #5
SamMargritz00
I'm taking it into the interior shop hopefully soon, still trying to get this fuel injected 5.3 wired up, maybe he'll have some ideas, but I am putting a 6 inch speaker in on each panel so ill see what happens.
Old 06-28-2011, 11:33 AM   #6
SamMargritz00
And when I say easy to take off, I don't want to take the panel apart in different sections, I want it in one whole piece if that makes sense.
Old 06-28-2011, 02:31 PM   #7
Erik V
Mine are stock panels, but with the mounts removed from inside the boxsides, then the insert pushed outwards. Its a little tricky to get the bolts started, but they dont need removed to get the hard top on and off (not that its been on since 1996 anyways).
I'm thinking about redo'ing them someday, making them flush mount with a SS piano style hinge mounted low so they can tip outwards to get to the hard top bolts. Also mount some more speakers/subs in the back corners and retain access to those.
Erik
Erik V is offline   Reply With Quote
Old 06-28-2011, 02:55 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
I had an upholstry shop make these....heavy duty velcro holds the top in. It's a tight pressure fit at the bottom. and the ends have upholstry clips like on modern door panels that are hidden. Note the extra piece of wood at the top to hide the recessed area of the bedsides.
and...Here's a video I took
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-28-2011, 06:03 PM   #9
SamMargritz00
this is exactly what i had in mind. thanks for the info.
Old 12-14-2015, 11:27 PM   #10
themb2g
Has anyone tried using ABS plastic sheeting to make their panels? I found a company that can cut them to the right dimensions, and then you would just need to take them to an upholstery shop to upholster them.
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 12-14-2015, 11:41 PM   #11
hemi43
hemi43's Avatar
Don't do it !! ABS is not flat and will not make a nice looking panel. ABS is only good for panels if it's vacuum formed.
hemi43 is offline   Reply With Quote
Old 12-15-2015, 12:37 AM   #12
themb2g
does it depend on the thickness of the ABS? it seems like a particle board or any other type would also flex.
http://www.tapplastics.com/product/p...o_size_plastic
Old 12-15-2015, 11:36 AM   #13
JJH Jimmy
JJH Jimmy's Avatar
I made mine out of 1/8" HDPE plastic sheet i got from Menards and then had my upholsterer cover them with the same material he used on the seats. I was worried that they would distort when they got hot in the sun but so far they have held up very well.
Page 9 of my build thread has a few more pictures.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-15-2015, 02:02 PM   #14
tubbedII
needs more $$$
tubbedII's Avatar
I was going to use 1/8" MDF for mine so I could cut out the patterns I was hoping to make as well. Then pre-drill all the mounting holes and cover with fiberglass resin on both sides to make it water proof before wrapping material over it all.
1970 2wd Blazer
Old 12-15-2015, 02:29 PM   #15
notsolo
notsolo's Avatar
I made mine out of 1/2" pvc, Home centers( sometimes Home Depot has it. AZEK is the brand name comes 4 x 8 sheet, about $80.00 will do both sides. I glued and shaped a thicker piece same stuff with pvc cement on top to match the contour. Also Painted mine adhesion promoter and Urethane paint.
notsolo is offline   Reply With Quote
1972 blazer, rear panel
