Old 07-27-2011, 01:36 PM   #1
4x4chvy
4x4chvy's Avatar
EGR Delete & Custom chips - Info/Links
This thread is NOT FOR ARGUING about what EGR does, or if it sucks, or whether deleting it has any benefits.
This thread is only here to save people time, aggravation and money by providing links to QUALITY parts & services.
Most of the pollution crap has been off my truck for years. I finally deleted the EGR valve and EGR solenoid. Because my Blazer is TBI - I had a hard time finding a Block Off Plate that lined up with the bolt holes in the GM TBI manifold (Ya, the carb'd EGR block off plates are cheap and easy to find... but they DON'T work for TBI.)
...and I needed someone who knew wtf when programming chips.
This guy Jim is a one man machine shop and does outstanding quality work:
http://www.custombilletworks.com/products.php
(541) 760-7292 and he returns calls.
This guy programs chips for performance & towing. He'll delete the EGR off your chip so your truck isn't throwing codes at you, or program you a custom chip for your truck.
http://www.tbichips.com/truckmods.htm
He also has a store on ebay. Click here.
"Go Hard - or Go Home!"
4x4chvy is offline   Reply With Quote
Old 07-30-2011, 11:35 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: EGR Delete & Custom chips - Info/Links
Thanks for the info!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-30-2011, 09:04 AM   #3
Berg
He has the 1980's 454 EGR Block-offs also and the L98 kit looks interesting too. I wish I knew about that when I had the El Camino and the other K5 set up with EFI
1970 Chevelle SS396
1984 K5 Blazer -First Truck!
1999 Big Block K2500 'Burb
Berg is offline   Reply With Quote
Old 08-30-2011, 11:02 AM   #4
thirdstreettito
Resident of Here
He will be doing my custom chip. I'm going to 383 my 88 burb with a vortec engine.
~Bradley~
Miss having a truck
Old 08-30-2011, 11:18 AM   #5
lyrikz
PITbut
lyrikz's Avatar
Good info.
On my 2008 Dodge mega 6.7 diesel, i deleted the dpf/cat/ egr/ egr cooler, oxygen sensors, and installed a smarty jr tuner. On the medium power tune i still get 5mpg more accross the board. Highway or city or towing.. My towing went from 10mpg average to 14mpg.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 05-01-2012, 03:49 PM   #6
dgreen
do i have to get a chip if i delete my egr?
dgreen is offline   Reply With Quote
Old 05-07-2012, 11:34 PM   #7
454Subb
if you dont it will trip a code at cruising speeds. I bought an highrise dual plane carbed intake for mine without the egr port, and my vortec heads require way to much work anyways. But i left the egr solenoid hooked up and just capped the vac line. When i had the VSS still it would trip a code around 45mph, so i solved that by installing a np205 and not hooking up a VSS.
454Subb is offline   Reply With Quote
Old 08-28-2016, 01:29 PM   #8
True
Hey I live in nd no emissions here I need help bypassing vacume lines on a 1985 305 chevy c10 I bleep my last motor because I was taking short cuts
True is offline   Reply With Quote
1987, blazer, chips, egr, tbi
