08-08-2011, 04:04 PM | #1 |
1965 Chevy C10, 2005 4.8L/4l60
Bag ??'s RE8 or 2500"s for rear baggin?
I found a guy close to me selling slightly used ( I havent seen them) Slam Specialties' RE8 and 2500's, which one would be better for my truck on the rear?
Thanks,
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-08-2011, 04:15 PM | #2 |
Re: Bag ??'s RE8 or 2500"s for rear baggin?
I had 7" bags on the back of my 68 originally & feel the smaller 6"/2500's would have been a better choice because it would have taken slightly more air pressure to achieve the same ride height. The larger bags needed to be @ <30psi to get the ride height I wanted. That low on pressure caused a bouncy ride. I wound up going to a 2" lowering block & bumped air psi up to 35psi. made a big difference in ride quality (no other changes were made).
When I set-up my 64, I went w/the smaller 2500's just for this reason. Ride Tech also recommends the smaller 6-6.5"/2500 bags for the 6x-72 truck arm rear suspensions if you need a professional opinion.
