08-18-2011, 09:56 PM | #1 |
drop spindles
i have a 83 short bed and i have it lowered with a flip kit and springs and im wanting to take the springs out and put spindles. so i got a good deal on a set of belltech drop spindles 31200 is stamped on the back of them. the guy had them on a 76 half ton and when i looked them up it said they were for like a 70-72 or something. so will these work on my truck if so what all do i need to make them work? i dont want to start to put them on unless i have everything i need. diff rotots,callipers,a arms. ect
any help will be much appreciated. thanks bryce |
08-18-2011, 10:00 PM | #2 |
67-72 parts collector,…
Re: drop spindles
3120= 71-72 spindle
3100= 73-87 HD spindle for 1-1/4" rotors 3200= 73-87 LD spindle for 1" rotors. What is the width of the rotors on your '83?
08-18-2011, 10:02 PM | #3 |
Re: drop spindles
i have not measured yet. so does that mean its not going to work? because its for a 71-72?
08-18-2011, 10:05 PM | #4 |
Re: drop spindles
just went outside and measured. looked to be 1in
08-18-2011, 10:12 PM | #5 |
Re: drop spindles
I don't know what to tell you.
If they said 3120 they would be 71-72. The 31200 makes me think they are a 3100 or 3200 spindle casting. I've never seen 31200. Either way the 1" rotor spindles are different from the 1-1/4" rotor spindles. So are the bearings, rotors, and calipers.
08-18-2011, 10:15 PM | #6 |
Re: drop spindles
well hell. i guess i will just have to try it i guess.
08-18-2011, 10:17 PM | #7 |
Re: drop spindles
Even if they are 71-72,... they can be made to work.
08-18-2011, 10:30 PM | #8 |
Re: drop spindles
Hey Guys
There is a 31200 belltech spindle. I just went through all of this on some used spindles for Krusty. I have it written down at work, but call belltech teck department. 31200 can be any of the 3, best i remember. They can walk you through it. Steve
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
08-18-2011, 10:40 PM | #9 |
Re: drop spindles
i called them and they were very short with me and wouldent try to help. (sounded like he didnt know what he was talking about)....yeah if u could figure it what u did to his truck to make them work that would be great
08-19-2011, 07:47 AM | #10 |
Re: drop spindles
I want be back to work until monday. Email me or pm me monday if you still need info. I have all info. in my locker at work, with the guys name that i talked to several times. HE was the only guy there that new what he was talking about. Let me know.
08-19-2011, 07:52 AM | #11 | |
Re: drop spindles
You will need: 1) 71-72 upper ball joints 2) 71-72 outer tie rod ends 3) 1-1/4" rotors 4) calipers 5) bearings If they are 73-87 HD spindles: You will need: 1) 1-1/4" rotors 2) calipers 3) bearings If they are 73-87 LD spindles: You will need: Nothing,...unless your original parts are worn.,
