![]() Join Date: Feb 2011
WTB Frame Horns for a 1972 4WD Blazer Frame
I am looking for both frame horns off of a 1972 4WD Blazer frame so I can replace the damaged ones I have. I would like to be able to bolt up a stock bumper. Thanks.
Just like to part out trucks!!
Re: WTB Frame Horns for a 1972 4WD Blazer Frame
Front or rear frame horns?
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Front. Thought I was forgetting something.
Posted via Mobile Device |
I have some out there, even have tow hook holes from factory. I cut them off right in front of spring mount. I'll get pics here in a bit. Thanks Randy
Thanks Randy. No hurry at all. They won't be used for a while.
not perfect but not bad, one crack and one hole where tow hook mounts on each one is wollared a bit
I will keep these in mind for sure, but where I'm not in a hurry I think I will hold out for a while to see if a nicer set comes along. Thank you so much for taking the time.
Stalker Nate
I might have a good set for you and I'm local so no shipping or anything. I'll be down in Seattle area Sept 24th I think for a buddy's grand opening at a car shop. I can leave them down there and you can get them at some point in the future unless you make a road trip that weekend.
I'll take some pics of the horns and post them up later on today.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
That sounds good. Thanks.
Hey guys,
I need these front horns as well. I plan on using them as a guide to have some fabrication done to factory specs. This might be a random question, but do you think that you might be able to trace these and scan me an image that I can give to the welding shop? Anything w I'll help! Thanks! Posted via Mobile Device |
![]() Join Date: Mar 2004
I also have a pair and can get pics tomorrow.
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
Hi, also looking for some rear frame horns. About from the last body mount and back. Also would like to find a rear cross member. For 1969 Blazer. Thanks and let me know what you might have. And shipping to 85929.
#13 |
![]() Join Date: Sep 2006
trying to sell my frame as a whole but will cut up if i dont get any bites its a 69 blazer 4x4 thanks
#14 |
If anyone is still looking, here's a pair i have off a 69 blazer frame. They are in nice shape. I can cut them whatever length you need.
#15 |
have set too , havent cut them off so can be cut where you want thanks jimmy
#16 |
Do you have the rear frame horns for a 72 Blazer?
#17 |
![]() Join Date: May 2011
#18 |
I need both rears....
#19 |
#20 |
Here is what I have depends on how long a piece you need they are rusty thin around the body mounts.
#21 |
They do look pretty thin.... Is that some welds I see? I'll check my Blazer for what length I'll need. It's at the mechanic now getting the engine put back in... ( a two week job has taken almost a month !! ) I'll show these photos to the guy and see what he thinks... thanks !!!!!!!
#22 |
"Trucks with Class"
![]() Join Date: Jul 2000
This thread is 7 yrs old.
#23 |
How much would they be with shipping to 49401 ??
#24 |
#25 |
No I haven't... it's in the shop now getting the engine put back in. They are having a hard time hooking up the carburetor linkage because the mounting bracket came up missing during the rebuild. I need a throttle linkage for a manual transmission, 350 sb and an Edelbrock 4 bbl carb. As far as length... the longer the better I'll say for now. I'd rather have too much than not enough. My zip code again is 49401
