09-01-2011, 06:43 PM | #1 |
hood
Hi, my dad and i are building a 68 c10 from ground up everything is going well except for the hood. the lines are lines up nice its just the rear of the hood. eveytime we open then close the hood the rear of the hood has to be pushed down to line back up with the fenders. these are brand new hinges but are old springs could this be what is kkepin it from going all the way down in the rear? thanks in advance.
09-01-2011, 09:43 PM | #2 | |
Re: hood
09-01-2011, 09:51 PM | #3 |
Re: hood
Mine does that too! My hinges/springs are original. Haven't really cared to look to see why, so it'd be interesting to see if you find the cause.
project: "my happy mess" |
09-01-2011, 11:07 PM | #4 |
Re: hood
09-02-2011, 12:12 AM | #5 |
Re: hood
I loosened the hinge bolts and pushed the hood up as far as it would go. While holding it there, I retightened the bolts. Seemed to cure most of the issue.
Not my idea, I read it somewhere originally.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
09-02-2011, 01:01 AM | #6 |
fat old dude
Re: hood
my friends truck does the same!
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
09-02-2011, 01:52 PM | #7 |
Moderator
Re: hood
This is your solution.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-02-2011, 03:01 PM | #8 |
Re: hood
09-02-2011, 03:07 PM | #9 |
Re: hood
X 3 Mine drove my crazy always having to push the hood down everytime. Had a nieghbour body guy fix it for me. Now I have to take the hidge off to get the heater core out and I am nervous I'll mess it up again.lol
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
09-02-2011, 03:59 PM | #10 |
Scrapper 1
Re: hood
Me i rather have a hinge problem instead of being cold
09-02-2011, 08:17 PM | #11 | |
Re: hood
Ditto! The timing of this thread is incredible....just looking at this the other day.
I must be wrong though, cuz 3 or 4 of yuz have done just like dmack91. Can someone explain how this is so?? |
09-02-2011, 08:19 PM | #12 | |
Moderator
Re: hood
09-02-2011, 09:09 PM | #13 |
Re: hood
okay it worked perfect. thanks for the help i see i wasnt the only one who was having this problem.
1 raise hood and loosen the three hinge bolts to the fender. 2 push the hood up in the center as high as possible toward the celing. 3 while holding upward pressure have someone tighten the bolts. THANKS GUYS. |
09-02-2011, 09:39 PM | #14 |
I am a Referee of life.
Re: hood
Drill two small holes(one at each end of the hinge)all the way thru the hinge and mounting area.Makle them just big enough for the bit or a small nail to go thru.Remove the hinge and do what you need to,then when you put it back just use the pins to align it.Then tighten it down right back where it was.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-02-2011, 10:11 PM | #15 | ||
Re: hood
09-02-2011, 10:15 PM | #16 | |
Re: hood
Or, loosen up/drop the back part of the inner fender well....I went this route because it was easier to do solo. |
