Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-14-2011, 09:07 AM   #1
dakas
dakas's Avatar
Isuzu pup
HELP
I was looking for a repair manual for the 94 Isuzu pip I just bought, there doesn't seem to be one !! They run to 93, but someone mentioned that it is the same basically as the Chev S10 ??
I need the routing of the vacuum hoses, some of the lines are broken causing it to run poorly...any help?
dakas is offline   Reply With Quote
Old 09-14-2011, 03:26 PM   #2
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: Isuzu pup
Originally Posted by dakas View Post
HELP
Its the same thing as a S10, or GMC Sonoma
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 09-15-2011, 09:52 PM   #3
lloydk
Re: Isuzu pup
95 was the last year, after they went same as s10, I went to the main library and made copys of what I needed
67 GMC, SWB, 472 Cadillac, Turbo 400, 273 rear
lloydk is offline   Reply With Quote
Old 09-25-2011, 05:17 PM   #4
dakas
dakas's Avatar
Re: Isuzu pup
I have a 94 PUP the manuals end at 93...I have a problem that I THINK is related to vacuum hookups, it "hunts" about 2-300 rpm up and down at idle...annoying that I can seem to find the problem
I bought a chev manual for the small pick ups of that era but they seem to have different engines...anyone have a vac hose "plan" in pictures?
Old 09-25-2011, 10:37 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Isuzu pup
You can find great info at www.autozone.com. They wiring and vacuum hose diagrams available.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-06-2011, 09:24 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Isuzu pup
This is the place to check , they where still Isuzu after the Luv for quite a while . Pretty good little trucks .
http://www.IsuzuPup.com
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
