09-17-2011, 08:41 AM | #1 |
Semper Fi!!!
I want a Lighter rim!
Right now on my Sonoma I have my Corvette rims, And they look real good dont get me wrong. But I want something like 100 pounds lighter . The 2.2 I got in it, is hurting for power as it is, it dont need help from the vette rims. So what kinda alm rims are you guys running?
Brandon... "IT ONLY TAKES EVERYTHING YOU GOT!!" Semper Fi |
09-18-2011, 09:26 AM | #2 |
Re: I want a Lighter rim!
Changing rims won't help. Changing tires will. A wider tire can effect rolling resistance. Or type of tire too. Narrow Passenger type tires roll easier than wide off-road type.
We switched from bridgestone Dueller's to suv type BFG longtrail's and what a difference. Also tire height effects a small motor too. Too tall. Too wide. Hard on power. What kind of tires you got and what size? |
09-19-2011, 12:37 AM | #3 |
BAD BOW-Silverado XST
Drop down to a tire that is only 7" wide. Anything larger will drag it down.
09-19-2011, 08:09 PM | #4 | |
Old member
They are complete though. $275.00 or Best Offer over $200.00 I'm a East Lincoln grad!
