Old 09-29-2011, 11:07 PM   #1
Bonechip67
Are the cabs from 47 to 54 all the same?
Im sure this has been asked, but are there any major diff's from 1/2 ton to 1 ton cabs? Will they all interchange? You can sometimes find a pretty decent 1 ton cab and was wondering if it would fit on my 1/2 ton frame.
Bonechip67 is offline   Reply With Quote
Old 09-29-2011, 11:12 PM   #2
sweet70beast
sweet70beast's Avatar
Re: Are the cabs from 47 to 54 all the same?
Yes all cabs from 47 to 50 and 51 to 53 and 54 to 55.1 are the same other than some minor cosmetic differences. This is from half ton all the way up to 2.5 ton.
47-50 has the drivers side vent door 51-53 does not, 54-55.1 has a one piece windshield, however they are all interchangeable with each other.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 09-30-2011, 10:29 AM   #3
mknittle
mknittle's Avatar
47-48 had three point cab mounts.49 to 55 first gen have 4 point mounts with shackle like leaf springs
1 ton cabs are the same as 1/2and 3/4 ton. they change from 11/2 ton up.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-30-2011, 10:32 AM   #4
MrTucker
MrTucker's Avatar
also, gmc and chevy cabs are the same, even produced from the same factory.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 10-01-2011, 12:52 AM   #5
Bonechip67
What about fenders?? I know the larger trucks wont work, but is there a difference between the 1/2 and 3/4? I went to buy some inner fender wells and the guy showed me 2 different lengths..
Old 10-01-2011, 10:04 AM   #6
mknittle
mknittle's Avatar
same with the fenders.
http://67-72chevytrucks.com/vboard/s...d.php?t=484509
Mark
My GMC build.
Old 10-01-2011, 11:05 PM   #7
Bonechip67
So they are the same cab and fenders up to 1 1/2 or 2 1/2? Got some conflicting answers here and I just want to make sure before I purchase a big rig just for the cab and maybe fender. Thanks for all the info guys!
Old 10-02-2011, 02:44 PM   #8
mr48chev
mr48chev's Avatar
1/2 and 3/4 tons have the same fender.
This one does have a frenched headlight though as it is the one off my truck.
Note the length of the wheel opening.
This is the fender on a 1-1/2 ton standard cab 51 truck
Note the longer opening with less material at the back of the fender and actually a more nicely rounded opening. On a truck running oversize rims and tires this might actually work better than the smaller opening.
Here are both the 1/2 ton on the bottom and the 1-1/2 ton together
Old 10-02-2011, 06:32 PM   #9
mknittle
mknittle's Avatar
sorry I meant up to 1ton. I have 2 1ton trucks that have the same fenders as my 1/2 tons 11/2 ton are as mr48 says.
Mark
My GMC build.
Old 10-02-2011, 07:50 PM   #10
Dan Bowles
AD Addict
The 54/55S1 GMC and Chevy cabs have different dashes. All the other years are the same between the two.
Dan Bowles is offline   Reply With Quote
Old 10-02-2011, 09:24 PM   #11
mr48chev
mr48chev's Avatar
When I was a pre-teen my stepfather at the time and his cronies claimed that the GMC had a heavier frame than the Chevys but I've got a half ton GMC frame setting out here to put under my 48 and the metal is the same gage. I think some GMC owners of new trucks make the same claim though and they come down the same assembly line.
Old 10-03-2011, 02:59 PM   #12
Dan Bowles
AD Addict
They are Proffesional Grade, dontchaknow! At this stage of the game, I have no idea why there remains 2 GM truck divisions. It is just badge engineering.
Old 10-03-2011, 05:18 PM   #13
MrTucker
MrTucker's Avatar
You're right, I should have clarified that. 47-53 cabs are identical, not 54-55.1
Old 10-04-2011, 10:39 AM   #14
mr48chev
mr48chev's Avatar
So that they can sell trucks at two dealerships in the same town or local area.
They even took away the GMC franchise from one dealer here in town and gave it to another so that both lines weren't under one dealer. He has separate lots across the street from each other but that was too close for GM.
Old 10-06-2011, 11:01 AM   #15
paulspickupparts
There are a whole bunch of differences . Almost year by year. Early trucks had two front cab mounts and one rear. LH Cowl vent. Smaller channel over the steering column. Different bolt pattern for speedo and gauges. Different door strikers for turn down handles. No in cab tank. Held in place by screws weatherstrip retainers around doors. Cable seat adjusting. Overlapping inside windshield moldings. Many other differences
Later cabs eliminated cowl vent on LH side and went to four point mounting system. Different mounting pattern for speedo gauges. Different door strikers. Higher channel for steering column. Slide in door weatherstrip retainers. In cab tanks. Track seat adjusting. Non overlapping inside windshield moldings.
54 up has many more differences. 1 piece windshield,different dash. Different column clamp . Different front cowl vent.
Sorry I did not break down by year but some changes changed by year while others did nto. But I would eat up 10 pages as not all changes occured at the same time. So it was a constant state of flux. Many other changes I have not listed . It would take too many pages and I type too slow. Thanks
paulspickupparts is offline   Reply With Quote
Old 10-15-2011, 10:44 PM   #16
Bonechip67
Ok, so I found a 1 1/2 ton truck with a decent cab. is this the same as the 1/2 ton cab? also, its a 48, what if anything would I have to do to make it work on a 53 frame? Any info would be great! Thanks
Old 10-15-2011, 10:56 PM   #17
paulspickupparts
Rear cab mounts. Fronts will be the same.
Old 10-15-2011, 11:12 PM   #18
Bonechip67
So other than the rear mount they are the same? Didnt know if there was a size difference and if the fender holes will line up. Also, think I could change out the rear cab mount without too much trouble?
Old 10-16-2011, 12:09 AM   #19
paulspickupparts
Fender holes will line up and will work. The difference is in the fender. See above. You can probably adapt the rear shackle mounts from a 53 if you have availablity. I should have some around if not.
Old 10-16-2011, 09:48 AM   #20
Bonechip67
Thanks, i may take you up on that Paul! Just wanted to make sure they are interchageable. Some say the 1/2 tons to 1 tons are, and others say up to 2 1/2 are.. Just want to make sure before I go though the trouble of tearing it off the frame and dishing out the dough that it will work.
Old 10-16-2011, 12:05 PM   #21
paulspickupparts
The cabs will work and are the same but stay away from the fenders and front clip parts as they are different and don't mix well together. Even the hood hinges are slightly different . Use pickup only parts for the rest of your build. At least as far as sheetmetal.Good luck.
