Old 10-06-2011, 11:58 PM   #1
rwhit57
rwhit57's Avatar
Turbo 350C trans with what gear ratio ?
I have the 350C turbo with 2.73 gears. I'm wanting to go to lower gears, 3.08 or maybe 3.42. I'm wondering if any of you have a 350C and what gears came with yours or what's in it now. I drive my truck on the highway a lot and I don't want to go too low. It just seems like it's always falling on it's face. What do you guys recommend?
rwhit57 is offline   Reply With Quote
Old 10-07-2011, 07:07 AM   #2
Hazieview
Building Dreams out of Dimes!
Re: Turbo 350C trans with what gear ratio ?
What size tire are you running?
With your gear ratio running a 25" tire and a 31" tall tire can make all the difference in the world.
Look online for a speed/rpm calculator. Like this one.
The gear ratio of a 350th transmission is 2.52, 1.52, 1
Hope this helps!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 10-07-2011, 06:40 PM   #3
rwhit57
rwhit57's Avatar
Thanks. I looked for one of those. That helps a lot. I'm thinking 3.42s might be a bit much for as much highway driving as I do, at least until I get a 700r4. I'm not sure the 3.08s are worth the change.
