10-13-2011, 12:14 AM | #1 |
Tripple Five Fanatic
IR 5HP air compressor pump knocking.
I got this Ingersoll Rand 5HP 80G compressor from a friend however it has a bad knock and I would like to fix it.
Model #: TS5 5HP 80Gallon 15.8 CFM @ 90PSI I found the rebuild kit and would like to try to rebuild it myself however not sure if I can do it correctly. It's hard to find a repair shop around me also. The rebulid kit #:85581486 Should I try this myself? I've rebuilt VW engines and just replaced the topend on my LS1 motor. I have looked for a rebuild manual for this pump and cannot find one, If I can get the torque and play specs I would try it? [
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
10-13-2011, 07:50 AM | #2 |
Re: IR 5HP air compressor pump knocking.
Sure its something you can do. The small compressors are fairly easy to do. You have a compressor there is no pump. Pumps pump liquid not gas.
10-13-2011, 10:22 AM | #3 | |
Thanks for the correction. Tri5
10-13-2011, 02:44 PM | #4 |
could alway buy a replace ment pump heres one i dont know it it fit or not
http://www.ebay.com/itm/Ingersoll-Ra...item3a6b389091
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-13-2011, 03:22 PM | #5 | |
Tri5
10-13-2011, 03:31 PM | #6 |
I think I'm going to try to get a new one. Talking to a friend, he said it's getting ready to throw a rod. His recommendation was that the cylinders can get out of shape because it's air cooled and that can cause other issues.
Any thoughts on that? Tri5
10-13-2011, 07:54 PM | #7 |
If its been overheated or run low on oil there are a lot of problems you could run into trying to rebuild something that isnt rebuildable due to wear issues. Its probably cheaper to get a replacement.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-13-2011, 09:34 PM | #8 |
the exact replacement pump for that model is 1500 and up i think i'd scrap the thing and buy a whole new one
http://www.google.com/products/catal...ed=0CFYQ8wIwAA
10-14-2011, 01:07 AM | #9 | |
http://www.harborfreight.com/145-psi...ump-67698.html Tri5
11-13-2011, 05:08 PM | #10 |
Tri5 did you ever open it up and take a look? If it is still something you are thinking about check out marcuse and sons compressors in FT Worth Texas. They don't have a great website, give them a call. They sell aftermarket compressor parts at usually half of what OE parts cost.
11-15-2011, 11:48 PM | #11 | |
Tri5
11-16-2011, 12:14 PM | #12 |
The website for Marcuse stinks. They do have the best stock of aftermarket compressor parts around. I always call them. The popular models are usually 1 to 2 days to ship for an overhaul kit. Be sure to tell them you want aftermarket. Sometimes They will resell oe parts if the aftermarket are not available.
Posted via Mobile Device |
01-02-2012, 12:25 AM | #13 |
Finally got the rebuild kit and will start working on it this week, I need a honing tool to make sure the cylinder walls are round. The kit is complete with instructions and specification, only thing I didn't get is pistions, so hopefully the pistons are still in good shape.
Tri5
01-02-2012, 12:57 AM | #14 |
It's not a race engine. I have ran some pretty ugly pistons in compressors. With long skirts on the piston I just Emory cloth them nice and smooth. I have done over 20 recips and not bought a piston. Did your kit come with clearance specs? Did you end up with a genuine ir kit?
01-02-2012, 05:04 PM | #15 | |
The kit is a genuine IR kit, I actually got a couple bonus pieces, I got one new 2" piston and a air filter which is good, so all I need to really worry about is the larger piston and the cylinder wall. I got everything else for upper and lower end of the pump. Tri5
01-02-2012, 07:58 PM | #16 |
Good luck on getting actual clearances from IR. Were the cylinders scared.
On a side I would highly recommend slowing down the compressor final speed if you can live with a little less cfm. It will run cooler and last much longer if you do. The engineers try to get every cfm they can but they don't expect them to live more than 5 years. Posted via Mobile Device |
01-03-2012, 01:03 PM | #17 | |
Haven't cracked it open yet, I'll do that this weekend. Don't know I can get that info about clearance but I'll try to ask the vendor I got the kit from. How do I slow down the speed? 5 Years, really? then it doesn't make any sense to really invest alot of $$$ into a compressor then. Tri5
01-03-2012, 02:14 PM | #18 |
5 years really i got an ir 5 hp compressor running at 175 psi at work thats goin on 10 years old with only a vavle job and a motor swap to the 3phase power motor
01-03-2012, 06:55 PM | #19 |
How often is your compressor used? Daily, couple times per week or constantly?
My intentions are to use it as much as possible to get my truck finished then not that much. Tri5
01-03-2012, 10:30 PM | #20 |
ours is used daily at work turn it on at 8am and turn it off at 6pm had the vavle reworked about 6 months ago and when they took the head off there was no wear in the cylinders could even see the hone marks
01-04-2012, 10:25 AM | #21 |
5. Year expectation is when a retail store compressor, is asked for daily service. 10 years is great on a recip asked for daily service. I bet it is a t30 not a ss or ts series. I also bet it cycles less than 5 times an hour.
Tri 5 for the use you describing that machine is going to be fine. It would blow up pool floaties and air up the occasional tire for 50 years. Just change the oil every now and then. Posted via Mobile Device |
01-04-2012, 01:04 PM | #22 | |
Tri5
01-04-2012, 05:00 PM | #23 | |
you hit it right on the head its a t30 twin compressor this is what ours looks like
01-28-2012, 07:54 PM | #24 |
I finally started tearing the pump down, the top end had a lot of crud on it after removing the head, maybe someone opened it up before. My buddy who is a mechanic watched me do the work and checked everything (pistons, rods, head) and said he does not see anything that would cause the type of knocking I was talking about.
The cylinders look almost new, still have cross hatch, the crank show a slight brown ring where the smaller piston rod connect, the rods looked good. He thinks it could the sheaves that could be the issue because it weren't sitting on the pins once the head was removed. I took some pictures. He'll take the crank to get it polished and mic the cylinders, then I'll start putting it back together. He also want me to get a new larger piston since everything is going to be new except for the crank and large piston. Is it really necessary if everything looks good? Tri5
01-28-2012, 08:44 PM | #25 |
wow that thing is dirty!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i'dd just clean it up and rering it as long as its not cracked
