SM420 is shot
Ok a couple of weeks ago, I went to leave work and the truck went bang. Has an SM420 tranny and a t221 tcase. Today I finally got a day off and pulled the tcase out. The output shaft on the tranny has splines that are worn to a knifes edge. The input side of the tcase has NO spline, they are worn off, I assume the final striping was when I heard the bang. So here is my dilema, do I do the NV4500 swap I have been talking about on my NV4500 will it fit thread, or do I find an output shaft for the tranny and an input collar for the tcase. I think the less expensive route may be to rebuild the sm420, but not sure. Any thoughts??? This was my daily driver, firewood hauler, but now its lawn art. Truck is a 1/2 ton 4x4 69 chev with 327'
1969 4x4 Nothing beats a good rock drill and some dynamite |
Re: SM420 is shot
Easiest and cheapest route is probably just finding another SM420/T221 or SM465/NP205. I bought my 465/205 combo for a hundred bucks last year.
What?
Re: SM420 is shot
I agree, SM465/NP205 would be the most fast and economical way to go from the sounds of things.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: SM420 is shot
there should be a coupler between tranny abnd acse. i have the same setup and replaced the coupler before it sheared. So, you may just need the tranny shaft. i can get a pic of the coupler.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
Re: SM420 is shot
67 mater you are right there is a coupler between tranny and tcase, however the splines in the coupler are gone on the tranny side. The output shafts splines on the tranny are sharp, almost nonexistent, and the couplers splines are nonexistent. However on the tcase side of the coupler they are fine. So I need the coupler and the output shaft on the tranny.
Redcap I think I may have found a SM465 bolted to a 396, but not sure what tcase it has. What year were the 465s found in? The truck I found is a late 70's early 80's. The guy said I could have the motor and tranny if I come get it. Everything is supposed to run well. so we shall see
![]() Join Date: Feb 2007
Re: SM420 is shot
Hi odog,
The '70's to early 80's sm465's had the np205. The 465 granny gear is not quite as low as your 420 (7.0 v.s. 6.55) but regardless it's tough to beat. If you could get your hands on the assembly for a couple hundred bucks ish it would very take little maintenance before slapping it in. I forget the length difference between your 420/221 and the 465/205 combo. You may want to figure that incase you need to address driveshaft length differences. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: SM420 is shot
Thanks Steve,
I looked at the truck last night and it didnt look like a 205 tcase, but Im sure its a 465 tranny, its got the granny low then 1st 2nd 3rd on the shifter. But I am not sure, I need to do more research. I have a fresh 205 sitting in the shop if the one on it now isnt any good (the one on it looks tiny). I am kinda excited about the 396 that comes with the tranny. I probably will take it regardless, its kinda nice having extra stuff laying around. The guy I got my frame from when I built this truck had a 454 with an auto trans and the 205, with the drive lines. When I got the frame, he gave me the tcase and drive lines too, so maybe I will get lucky and have the right drive line.
Re: SM420 is shot
the only other tcase behind the 465 was the np208 later in the 80's. I dont remember if the 203's ever got slung behind the 465's in the early '70's but it's possible. You don't want that. I think I heard of the Rockwell 221 behind them too but don't remember. I have a complete 221, keep that in mind. I sold my 465's and used my last good 205.
Re: SM420 is shot
I know its not a t221, thats what I had behind the 420. Its a good tcase, strong, but after 44 years of hard use, its finally said uncle. I will look into the tcase on this one, is the 203 chain driven? I dont want that. how about the 208?
Re: SM420 is shot
ya that 203 is chain driven and it's a full time unit. You don't want that. The 208 is chain driven and aluminum cased but tends to hold up well unless you are pushing it hard in the back country. really you want the 465/205 as you know they are stout and plentiful.
Re: SM420 is shot
Ok when I looked at it, the truck is not full time, it has locking hubs, the tcase is aluminum, but not as big as a 205, so most likely a 208?? Also will a 205 bolt up without an adapter if it is a 465? I am leaning more and more towards this.
Re: SM420 is shot
If it's an aluminum case then it's an np208. They started that combo somewhere about 1985ish. You will need an adapter for the 205. It's about 6 inches long, has the boss for your shifter, and has a a figure 8 bolt pattern.
#13 |
Re: SM420 is shot
Didn't they switch to a 32spline output shaft on the sm465 when they started putting the np208 behind it
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
#14 |
Re: SM420 is shot
#15 |
Re: SM420 is shot
I don't remember if they did or not. They definitely used the 32 spline shaft with the 205 starting in late '88, as they also switched to the round bolt pattern. But I don't remember what shaft they used for the 208 when they started that combo a couple years earlier.
#16 |
Re: SM420 is shot
Red cap thank you for the links, that provided some good info. I think I am looking at a 465 with a 208 in which case I will go that route. Now I just need to get another day off to take it out and swap it in.
#17 |
Re: SM420 is shot
I would bet you money you are looking at a 465/NP208 combo. It will get you going, but keep your eyes out for a 465/205 combo to replace it. I don't think very much of the 208 case as I've destroyed a few of them.
#18 |
Re: SM420 is shot
Just an update, I got today off and I finally pulled the sm 465/np208 out of the donor truck today. Didnt go to bad, But I decided I am going to put my 205 on the 465. The 465 has a 32 spline output shaft and my 205 has a 32 spline female end that should fit, I guess now I just need an adapter that has a figure 8 pattern on both ends. Tranny looks in good shape, took the top cover off and everything visible looks good. Curious about the tcase though, it was filled with ATF, is this normal? I seperated the tcase and tranny and the output shaft on the tranny is long, about 8 to 10 inches. I will keep working on it, and updating as I go.
#19 |
Re: SM420 is shot
Alright, Appernetly I am a dumba$$. I got a 465 to 205 adapter, put a new seal in the tcase side, then got busy at work and didnt get any farther. Today I had time so I went and tried to bolt it all together. Well the little short shaft on the tcase side, (calling it a shaft, its about 1 inch long with female splines) is bigger than the seal on the adapter. They dont make seals this size come to find out. So I says to myself both tcase and tranny run on 80-90 so oil mixing should be ok. I try to bolt everything together and the tranny side of the adapter fits great, the output shaft slides right into the little shaft on the tcase, BUT the adapter WILL NOT fit on the tcase. The bolt pattern is the same, the little shaft fits inside the adapter, but I guess its the bearing? that sticks out about 1/4 inch will not fit int he recessed area on the adapter. The recessed area is too small. This explains why there is no seal. Do I have the wrong adapter? Is there more than one adapter for this setup? Im not sure what year tcase this is. I got it off a 72 with a 350 or 400 tranny, but it could be from any year I guess.
I dont need this running tommorrow or anything, but I would like it eventually. I guess I could do another option, but I have questions about that as well. Can I bolt a T221 to an SM465? My 221's power collar is shot and it is only 10 spline. Is there a 32 spline to 10 spline converter/adapter? The tcase is 10 spline and the tranny is 32. What a pain this is turning into. Anybody have any thoughts.?
#20 |
Re: SM420 is shot
sounds like you have a coupler for the 32 spline 205 that came later but you are needing the 10 spline for the earlier years 205. I gota have another one somewhere here, I'll start looking tomorrow.
oh, went back a reread further back, maybe im wrong. lemmie know what I can do to help.
#21 |
Re: SM420 is shot
Steve, Maybe you are on the right track. Is there an adapter for the 32 spline 205 and 32 spline tranny, and one for the 10 spline tranny and 205. If so maybe I have the 10 spline version. I'm gonna do some research and see what I can find.
#22 |
Re: SM420 is shot
Well the difference between the two versions was the early year adapter was the 8 bolt "racetrack" shape and used the 10 spline female coupler. The later combo had a round pattern 6 bolt pattern and used a 32 spline female coupler. The input shaft on the 32 spline was larger iirc as the case opening was larger making room for the larger input bearing and again the larger diameter shaft. So just as long as you have the right bolt pattern adapter to case and the proper splined coupler you should be in good shape. Snaps some pics if you get a chance. Again I can snoop around as I bet I can find what you need if you indeed need different parts. I know I have an 8 bolt adapter but not sure about any more couplers.
#23 |
Re: SM420 is shot
I will try to get some pics after work tonight.
#24 |
![]() Join Date: Jan 2010
Re: SM420 is shot
If you decide to rebuild the 221 I have 2 spares I can pull parts from. I only have 1 TC outout shaft as I just sent 1 to another member for his rebuild. Just cover shipping and you can have what ever parts you need.
#25 |
Re: SM420 is shot
ok here are some pics of the tranny, tcase and adapter.
The ist pic is of the tranny side of the adapter. The second pic is of the tcase side of the adapter. the 3rd pic is of the tcase with the "short shaft" wih 32 internal splines. The 4th pic is of the output shaft on the tranny, 32 splines. the last pic is of the 465 to 205 adapter with the seal and the adapter that was on the tcase with its seal. Both adapters showing tcase side. Notice how the 465 to 205 adapter is smaller on the tcase side than the other adapter.
