10-17-2011, 06:36 PM | #1 |
Suspension Blues
Heres the story, When I first got my truck, the differential who moved when I shifted, cuz the plates that it sit on were rusted threw, so i just welded the u joints to the diff, yes i know now very good idea, well anyways here i am 3 years later, I go to put some water in my radiator, i parked on a slightly slanted hill, put some in, get in, push my clutch in, then boom!...I was like, was I on a stick or something, ill go look....Well my whole bed is almost sitting on my right tire, the control arm is laying on the ground, and the U bolt is snapped in half....now i tried grinding the u bolt off, really hard to hit the welds with that, now im going to try and torch it VERY carefully......heres some pics.......
10-17-2011, 06:37 PM | #2 |
Re: Suspension Blues
one more pic....
10-17-2011, 06:46 PM | #3 |
Ouch! At least you weren't driving down the freeway. Hope you get it all worked out.
Keith |
10-17-2011, 06:50 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
do you have new u-bolts? I would definitely replace both
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-17-2011, 09:58 PM | #5 |
I'm workin on getting new ones, does Autozone carry them?
Posted via Mobile Device |
10-17-2011, 10:29 PM | #6 |
Has more rust than truck...
Never seen a U bolt go, seems the trailing arms go first. Don't think AZ will have it, but any spring shop can make them.
10-17-2011, 11:23 PM | #7 |
I agree 100% Hate to see it happen but it could have been a lot worse.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
10-18-2011, 05:34 PM | #8 |
Well what I didn't want to happen, happen, put I tiny hole in the diff when I was cutting it off with the torch, can I just weld it back shut?
10-18-2011, 06:13 PM | #9 |
yes you should be able to if you have a strong enough welder to do it.
10-18-2011, 06:25 PM | #10 |
I have seen many diff u bolts in the back warehouse of my local napa they should be able to match one up
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-18-2011, 06:26 PM | #11 |
Well I went to Napa, and they didnt have any, and they couldnt even order one for me.
10-18-2011, 06:39 PM | #12 | |
67-72 parts collector,…
He's a board supporting Vendor. http://67-72chevytrucks.com/vboard/s...d.php?t=454824
10-18-2011, 07:50 PM | #13 |
I have a '70 GMC with Leaf springs on the back. When i replaced the springs with heavier ones az had the square u-bolts that were long enough to fit.(napa did not). You may try them especially if you have one to match up with.
Bigdog |
10-18-2011, 09:56 PM | #14 | |
laying low
There are 43 listed at Advance Auto Parts if you have one near you. http://shop.advanceautoparts.com/web...p2HomeClicked=
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-18-2011, 11:52 PM | #15 |
Try looking into auto carage shops, or truck shops like 4-wheel supply stores or rigging supply stores. I have had a few made back when I was into 4 wheeling. Essentialy it starts as a straight length of rod with the ends threaded, The threads are important too. Try your best to find ones with Rolled threads ,, not cut threads.. Rolled are much stronger. Once a length has been established from your old U-bolt they put it in a press and presto a "U"... Semi trucks and trailers break those often enough that alot of the repair shops keep a supply on hand.. they may even be able to direct you to someone who has the correct stuff if they don't have it. And keep in mind, They aren't that expencive, so do both u-bolts at the same time.. it's good peace of mind...
71 2wd Blazer My build, Restarted 05 Buell firebolt 94 1500 Z71 No rice for me,,, I'm full |
10-19-2011, 05:41 PM | #16 |
Ok thanks for all the help guys, ill let you know what I find.
10-19-2011, 06:26 PM | #17 |
Well i got to thinkin, and I just relized there was someone in my town that sells diffrentials, and puts diffs in lifted trucks, ill give him a call
10-20-2011, 11:01 AM | #18 |
Go to www.spectrac.com . You can get any U-bolt you want.
10-20-2011, 11:11 AM | #19 |
I have a brand new set of u-bolts on my shelf, PM me if you're interested in them.
10-26-2011, 07:31 PM | #20 |
Ok I got a new U bolt made, and got it all put back together, FINALLY...I was starting to have withdraws from not driving my truck
