10-23-2011, 05:04 PM | #1 |
Manual Choke Info Needed
I'm putting a manual choke in my '71 C/30 tow truck. I'm hoping someone could give me a picture of where the choke comes through the firewall on a post-68* truck with manual choke so I can drill the whole as close to where the factory did. Thanks in advance
*67/68 location would be just as good. Maybe they're the same place?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-23-2011 at 05:49 PM. |
10-23-2011, 07:32 PM | #2 |
Re: Manual Choke Info Needed
i got a gauge cluster out of a 72 c50 and put it in my 72 k20 and it has a fact location for a manual choke under the wiper switch. and there is a hole in the dash when you remove the gauge panel that i suppose was is there due to intercangability.
10-23-2011, 07:58 PM | #3 | |
10-23-2011, 07:58 PM | #4 | |
Active Member
10-23-2011, 08:22 PM | #5 |
Thanks you all. That picture with the holes labeled would be one I'd save. Only trucks with manual choke will have the hole. Pondscum,yes there is a place on every dash to the right side of the cluster for choke and/or throttle. I measured from the center of the wiper switch hole to find the center of the lower hole and drilled out a 1" hole in the cluster. I have the cable installed and now need to drill a hole through the firewall for the cable to pass through to the carb on the right side. I guess I could figure a good line to follow and just drill a hole where it seems best,but I'd rather put the hole as close as possible to the factory as I can so it looks original.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-23-2011 at 08:45 PM. |
10-23-2011, 09:09 PM | #6 |
Tim here's a pic of my 68. Only I can't remember if that's the choke cable or speedo cable. Maybe this pic will jog somebody else's memory.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
10-23-2011, 09:26 PM | #7 |
I am a Referee of life.
On my 68 it's nearly directly in front of the knob.I realize that you're looking for later model though.Maybe the firewall hole is in the same spot?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-23-2011, 10:12 PM | #8 |
Grandpa in the rustmobile...
I can get pix of my 68 but i dont know if it was originally a electric or manual choke truck
it originally had a sbc but not on the spid so i assume 307
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-23-2011, 10:22 PM | #9 |
10-24-2011, 06:46 AM | #10 | |
Fishingred,thanks for that picture. When you showed the first picture it made me wonder if you had a 6cyl. I think they run a different route than a V8. I realize now I should have added that I need the location for a V8.
On a 67/68 a truck came with manual choke unless the SPID shows the auto choke option. Quote:
I figure a V8 choke cable would have come though in the recess behind the motor to cross over to the passenger side. My truck has an Edelbrock spread-bore intake & Quadrajet. The intake has no well for choke. And,I just kinda like the added mechanical feature in such a truck.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-24-2011 at 06:52 AM. |
10-24-2011, 08:24 AM | #11 |
Active Member
Just in case they're in the same location, here's a pic of the cable location for my 68 GMC that I found this morning.
10-24-2011, 09:01 AM | #12 | |
10-24-2011, 09:58 PM | #13 |
Yeah,I'm sure now that V8s and I6s had different routing. Makes sense since the cable goes to opposite sides of the engine. I'd still like to see a picture of a V8 choke cable coming through the firewall.
10-25-2011, 07:22 PM | #14 |
This one is a 1971 C5500 with a 351E
This one is a 1971 C6500 with a 366 The rubber coated one is the choke cable. The other one is the throttle cable. As you can see, they both come through the same spot. |
10-25-2011, 09:31 PM | #15 |
That's great! Thanks!
