10-24-2011, 09:08 PM | #1 |
Power steering help
I changed out a growling powersteering box on my 1972 C-10 i went with a 1977 used box that seemed in good shape, at the same time i instaled a new pump from NAPA and fit it in to my Reservoir. Now the steering is a little to free. What i mean is its a little to easy to turn? I have a Finished 1971 Short wide. That has perfect feeling steering but it came that way when i bought it. What should i change to get the steering more firm. The box i installed is Quiet and tite and so is the pump. Thanks for any help you can give.
10-25-2011, 11:32 AM | #2 |
Re: Power steering help
Can you explain what exactly you mean an why is it a problem? I'm confused lol.
1969 Chevy c20(Miss Hackjob) |
10-25-2011, 11:46 AM | #3 | ||
"I ain't nobody, dork."
Maybe the later model box has a quicker ratio?
Is that what you're askin'? Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-25-2011, 12:00 PM | #4 |
You mean you can steer with 1 finger now?
1967custom |
10-25-2011, 01:23 PM | #5 |
Active Member
These types of steering gearboxes usually feel that way. Maybe your old one was too tight and your other truck has all tighter front end components.
I would start by making sure the gearbox is adjusted properly and that tierod ends, drag link, pitman arm and ball joints are in good shape. |
10-25-2011, 07:55 PM | #6 |
All of the Steering stuff is new. The truck steers Great its just that the power steering is to easy. Yes 1 finger easy. My other truck has a much firmer steering and I like it a lot better. It is the Quick ratio box now. But my other truck has that also. Any body ever try a Steering control valve? I bought one from Brothers. Its made by Heidts Rod shop and looks like it could work. but i was thinking it might be easier to change to a diffrent pump?
10-25-2011, 08:16 PM | #7 |
Here is a picture of the 71 i rebuilt in 2009. Can you tell what Steering box and pump it has?
