10-25-2011, 04:51 PM | #1 |
Help, truck just died on me...
My 1972 GMC just died on me on the way back to the office today from a job site. It's getting fuel, cranks over but won't start. I checked all the wires, hoses, etc that I could see and nothing out of place. I'm guessing ignition issues since it just died while driving. It's a 350/350 combo and converted to HEI. I just replaced the cap, coil, rotor, wires, etc back in March or so.
Thoughts? Thanks, had to leave it on the side of the road and get a ride back to the office (had 2 coworkers with me) and waiting for the tow truck to bring it home. Thanks!
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
10-25-2011, 04:55 PM | #2 |
Champagne Taste on Beer Budget
Re: Help, truck just died on me...
Get it back home and pull a spark plug wire and see if it's getting spark.
Then go from there. Good luck.
Coming Soon: Project 1970 Country Truck |
10-25-2011, 05:00 PM | #3 |
Check batt. Wire that plugs into hei cap. Mine came loose did the same thing.
Posted via Mobile Device |
10-25-2011, 05:52 PM | #4 |
I'll check spark when I get home, and checked the hei wires when I was there but you never know...can't wait to get home and get busy diagnosing so I can get to work in the morning!
10-26-2011, 12:58 PM | #5 |
Ended up being a fried HEI coil...as in the actual wires were burned! Don't know how that happened...back on the road!
10-26-2011, 01:08 PM | #6 |
I was going to say the module. Glad you got it fixed
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 Last edited by splehigh; 10-26-2011 at 01:21 PM. |
10-26-2011, 02:44 PM | #7 |
poor connections and poor gounding cause heat and wires melting
10-26-2011, 03:01 PM | #8 |
Tonight I'm going through all of my connections when I can get my truck out in my shop.
10-26-2011, 06:20 PM | #9 |
Make sure you are sending a full 12 volts to the HEI. If you use the factory power lead that your truck came with, you will be sending less than 12 volts since the factory wire was a resistance wire designed for use with the points system/ballast resistor. The HEI will run for a while with the lower voltage, but will eventually fry the module and/or the cap and rotor itself. Ask me how I know...
10-26-2011, 11:03 PM | #10 |
Old Skool Club
Make sure you use the heat sink compound that transfers heat from the module to the breaker plate. If you don't, it will cook the module.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
