Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-28-2011, 10:23 AM   #1
Will__L
? about dart big m
does a dart big m block mount in the same way as a mkIV bbc? ive got a 498bbc now and am thinking of moving up to a 540 or 565....just wondering if the dart big m block will "bolt in" to the same mounts
Will__L is offline   Reply With Quote
Old 10-28-2011, 03:14 PM   #2
kpeztruck
kpeztruck's Avatar
Re: ? about dart big m
Yes it should bolt up, just like the other engine. I have had both in my 5.30 index car with no changes at all. Both were 10.2 deck height. Paul
kpeztruck is offline   Reply With Quote
Old 10-28-2011, 03:27 PM   #3
kwhite4
Junior Member
kwhite4's Avatar
I have a 565 built with a Dart block and mounting points are the same as my old 468..
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 10-28-2011, 08:10 PM   #4
PGSigns
PGSigns's Avatar
If you want one done I have a 555 with a dart pro block. 906 HP
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-28-2011, 10:05 PM   #5
Will__L
thanks for the offer...but its going to be a street motor...not a race application...just going to build a big puppy dog....something that will make respectable numbers on pump
Old 10-29-2011, 09:18 AM   #6
PGSigns
PGSigns's Avatar
Still might be a viable option. Ad up what all the stuff new is going to cost and compare that to changing pistons, cams and springs in a race motor. I think it was close to 17K to do this motor and that was a few years ago. With the quality of parts you get by dropping the compression in a race motor you can end up with a better motor with better parts and still save money.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
