11-03-2011, 02:16 PM | #1 |
Easy Does It
Hub caps on truck question
I have a set of the chevy 4x4 truck rally wheels 73-87 style. I wanted to know if there is a way to use old style hub caps instead of the current bolt on centers ?? something with some type of clips to hold in place? anyone ever tried this have any pics. or know what to use. thanks
11-03-2011, 02:25 PM | #2 |
Check The Champ, Demonstrator
Re: Hub caps on truck question
I know a guy who welded the nubs from another wheel onto one of those 4 inch wide spares to put on the front end of his truck with the stock 64 15" cap. He wanted the stock look but in the big and smalls formation. The clip hubcaps are hard to find so any kind of ridge you put on the wheel the 15" hubcap should be able to snap onto. There could be a balancing issue afterwards however.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
11-03-2011, 03:58 PM | #3 | |
11-03-2011, 04:21 PM | #4 |
If you have a die made for a metal spinning shop they could spin an adapter like you said that could be screwed onto the wheel using the existing holes then click the hubcap onto the spun beaded side.
11-03-2011, 05:18 PM | #5 |
Easy Does It
heres a pic of the wheels and something similar to this for a hub cap
11-03-2011, 11:12 PM | #6 |
subscribed
11-03-2011, 11:33 PM | #7 |
I ran those 4x4 wheels with those exact same bolt on center caps on my 62 chevy stepside I had 10 years ago. What I did on my center caps was I had a friend cover the center (4X4) with a custom 3M decal bowtie matching the color of the truck and the rims. Looked great. Just an idea?
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
11-04-2011, 09:05 AM | #8 |
I think it would need to take a stock hubcap for this to be accepted, in that way we could run wider wheels that are inexpensive and still make the truck look fairly stock. I will see what we can come up with. Kieth
11-04-2011, 09:33 AM | #9 |
Just another idea,not older look,but newer silverado cap painted
11-04-2011, 06:41 PM | #10 |
EUREKA I DID IT, FOUND A SIMPLE CHEAP WAY TO MOUNT STOCK HUBCAPS TO RALLYE WHEELS....................IT LOOKS GREAT WILL SHARE WITH YOU GUYS AFTER THE PATENT IS APPLIED FOR..........KIETH
11-04-2011, 06:45 PM | #11 |
Cant wait to see!
11-04-2011, 06:46 PM | #12 |
keith Does it involve spoons from the kitchen?
11-04-2011, 06:59 PM | #13 |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
11-04-2011, 08:26 PM | #14 |
well fill us in i want to use camaro derby caps for centers in my truck rallies
11-04-2011, 08:33 PM | #15 |
Look at these...Maybe
http://www.google.com/search?client=...UTF-8&oe=UTF-8
11-06-2011, 12:26 PM | #16 |
Ok here we go----simple hub cap mounting system for rallye wheels:
1. Parts needed----grote steel insulated wiring clips part # 84-7018 I had these so do not remember how much they cost but I think about .50 each 2. We centered the hubcap on the wheel then traced the outline of the hub cap on the wheel, backed off about 3/16" and installed the clips. Hoping above all that it would work.......................... 3. Tried a 1957 chevy hubcap first---------------and it worked Would rather be lucky than good...... Wheel only with cap and trim ring 4. 57 chrome hubcap with tire I think it looks good, just think what it will look like on a truck and the wheel painted to match the truck 5. Wheel tire, trim ring , and a painted hubcap Now we just have to try it driving down the road but I will tell you it feels very solid and after it is installed it is hard to get the hubcap off since it is held in place by 4 clips..........when I removed it the first time it bent one of the clips back, then all you have to do is push it back in place. I think since the load will be centrifical (out ward) that the clips will work just fine, if not we could weld them in place Kieth |
11-06-2011, 12:50 PM | #17 |
Crafty lil devil you are, that looks great on there. Before taking it for a drive on the truck, take it to a tire shop that has one a tire balancing machines and let it go for a spin. Less likely to damage the cap or the truck. Can you post a picture without the trim ring please.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 11-06-2011 at 01:52 PM. |
11-06-2011, 01:44 PM | #18 | |
I will look for a pretty wheel just to set a hubcap on without the trim ring. I think it will look fine, I did go look around a little and found these, they might be ideal for doing the same thing but be made out of spring steel. http://www.iowa80.com/DirectionsWEB/...UB+CAPS+3+PACK will post up a picture later. |
11-06-2011, 01:50 PM | #19 |
Iowa 80 truck stop. Used to go there, HUGE lot. Those new clips might be spring steel, a little stronger than the cable clips. Had your thinking cap on didn't ya! lol
11-06-2011, 01:55 PM | #20 |
here they are....
to see the wheels like they should look the ones with the white hubcaps should be painted black and the chrome hubcaps should be painted the same color as the truck. I do have a set of 4 x 4 wide wheels that I am going to use on my 66 custom cab truck, they should look better still since they are deeper. Kieth |
11-06-2011, 03:04 PM | #21 |
Their going to look nice with any color and the stock painted hubcap. With a black wheel the slots will disappear making it look more like a stock wheel. Way to go Keith!
11-06-2011, 03:08 PM | #22 |
looks good an thanks for the tip
11-07-2011, 12:17 PM | #23 |
I just had one of those moments, after I saw that the stock wheel clips were $15.00 each......just said hmmmm there has to be a easier way. I am ordering some of the spring clips today and will try them, I think they will be better since they are spring steel, but one never knows if it will work correctly until we do it. Will let you guys know. Kieth
11-07-2011, 03:12 PM | #24 |
Pretty slick Keith!! I had been planning on running stock caps on 18" Nissan Titan steel wheels and had been wondering what kind of hubcap clips would work. Thanks for the tip!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-07-2011, 03:31 PM | #25 | |
It always irked me that the only option was to order wheel vintiques or others and spend a lot of money. The clips that I had found on all the chevrolet part websites were just a little pricey so I thought we should find a reasonable alternative...........and now we have. It looks like the nissan titan wheels really have a steep angle on them......you might want to look to the clips I used, or the 2 types which are also listed on the iowa80.com website and see which one works the best. here is a link to those clips that look to me like they may handle that steep angle and they are priced right. http://www.iowa80.com/DirectionsWEB/...%28Set+of+6%29 If you will scroll down to the recently viewed items you will see the available alternatives. |
