Old 11-07-2011, 12:58 PM   #1
crazeetxn
crazeetxn's Avatar
04 burb leaking coolant from somewhere
It's only got 150K on it For some reason though, on occassion, I'll come outside to a puddle of coolant in the garage. Don't notice it when I leave work, only have setting overnight. It's not all of it, but enough to make me notice.
I also notice the sweet smell when I get out of it during the day too. No moisture around the hoses and I didn't see a pet cock valve to check, but I just did a quick glance.
It's right in the middle of the vehicle in the front. Haven't removed the shroud to check the radiator, just thought I'd throw this out there.
Also, is there a way to pressure test these things? I didn't see a radiator cap anywhere, just fill it up through the resovoir.
Thanks all...
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 11-07-2011, 01:24 PM   #2
clinebarger
Re: 04 burb leaking coolant from somewhere
Water pump gaskets.....Seen it hundreds of times, Its also happened to both my 04 5.3L engines.
clinebarger is offline   Reply With Quote
Old 11-07-2011, 02:04 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Whens the last time you replaced the water pump?
Old 11-07-2011, 11:34 PM   #4
clinebarger
Most water pumps on these engines are replaced because of the pump to block gaskets are leaking.
In my opinion transmissions, fuel pumps, blend door motors & insterment clusters go out more than the actual water pump.
Old 11-07-2011, 11:34 PM   #5
crazeetxn
crazeetxn's Avatar
Never. Haven't replaced anything on it like that (knock on wood). Didn't even think to check that out. Used to being able to trouble shoot my '86 with a little more ease.
So what kind of job am I looking at replacing this thing?
1st - '68 long bed
2nd - '81 SWB
Old 11-08-2011, 01:08 AM   #6
Warrens69GMC
With 150k and water leaking from somewhere, the water pump should be checked or just replaced
As for replacement-
Old 11-08-2011, 11:51 AM   #7
crazeetxn
crazeetxn's Avatar
Well, the video showed him doing it in about 15 mins so I figure I'll be good
I appreciate the info. Looks like I've got my work cut out for this weekend!!!
1st - '68 long bed
2nd - '81 SWB
Old 11-12-2011, 01:25 AM   #8
bighaas79
Waterpump gaskets are a breeze in these newer trucks.
bighaas79 is offline   Reply With Quote
Old 05-07-2012, 06:59 AM   #9
Sierraslt03
While your coolant is down take off top hose and put a little tube can of preston fix or Barrs Leak in it and follow instructions. It will stop the leak... IF YOU CAN'TT FIND LEAK....
Sierraslt03 is offline   Reply With Quote
