11-11-2011, 01:22 AM | #1 |
15x6 6 lug steelies
I have a pair of 15x6 6 lug wheels that i bought with some tires and have no use for them. came off of a mid 70's 4x4 6 lug with 3.5-3.75 backspacing
$100 OBO shipped for both of them. Paypal preferred. Can get more pictures upon request.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
11-11-2011, 04:24 PM | #2 |
Re: 15x6 6 lug steelies
ttt
11-11-2011, 04:42 PM | #3 |
I wonder if those will fit over front disk on my 1966.
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
11-11-2011, 07:05 PM | #4 |
If you need some measurements to be sure i can go check. its no problem.
11-28-2011, 07:48 PM | #5 |
ttt
11-28-2011, 07:59 PM | #6 |
If you have 73 calipers i dont think they will fit. They hit the outer edge of the caliper.
1967custom |
11-28-2011, 09:12 PM | #7 |
Actually i think they would fit. They came off of a squarebody 73-87 so i think they would fit over the Disk Calipers.
11-29-2011, 09:50 PM | #8 | |
I'd like to be #2 in line behind ol skool chevy if they'll fit a disc conversion. Thanks.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
11-30-2011, 01:32 AM | #9 |
The only reason I put a .25 difference is because I can't tell the exact backspacing so I'm just ballparking it. I'll pull the numbers off them torrow to see what year they are. And I think you are #1 in line. Ol skool never replied to me so your first in line.
11-30-2011, 03:54 PM | #10 | |
11-30-2011, 07:40 PM | #11 |
You can tell by the rear of the wheel, if it's more square then angled where it goes to the center then it's for front drums. If more of an angled then it's for disc. Hope that helps you two figure it out.
11-30-2011, 08:24 PM | #12 |
It Looks to me like they would fit over a disk. the well in the center as you can see in the picture is the narrow kind and the numbers that i pulled off are k184 XX with JJ on the inside.
11-30-2011, 10:34 PM | #13 |
Yes they do look like they will fit over disk front, by the pics above. Maybe I worded it wrong, if the bend on the inner wheel is closer to the center piece (or right at it) it will fit over disks. The drum style have the angle starting further from the center piece. I would have taken them but the back spacing was not right for me. Hope this helps you figure it out.
11-30-2011, 11:17 PM | #14 |
Ok. I'm gonna cross my fingers and give these a shot. Do you take Paypal?
11-30-2011, 11:17 PM | #15 |
Thanks for your help thriftmaster. Went and looked at them again. the bend or curve starts immediately after the center tabs or whatever you would call them. and by what i understand the 8 stands for last digit year. so im gonne say they are off of a 78 chevy. written in the middle of the rim says "off mid seventies chevy 4x4" so that makes it more logical.
