11-23-2011, 02:58 PM | #1 |
Winter Time
Winter is setting in and I'm ready to replace my leaking heater core. Mainly for my girlfriend bc she gets cold. I've never replaced a heater core before and i have an idea of how to do it. My question is that do I really need to take the hood off as well as fender cover? If anyone has done this project can you give any suggestions? Any suggestion would be much appreciated
11-23-2011, 03:11 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Winter Time
what year truck bud?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-23-2011, 03:44 PM | #3 |
Re: Winter Time
1970 without ac
11-23-2011, 03:59 PM | #4 |
Its a Truck Thing......
Re: Winter Time
Hood no,
Inner fender, makes life easier unless you got the right tools to get to the bolts under the heater box....If its a CA truck, you shouldn't have any issues removing the inner fender well. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-23-2011, 04:00 PM | #5 |
Re: Winter Time
No need to pull the hood. Just remove the inner fender.
11-23-2011, 04:06 PM | #6 |
Re: Winter Time
my life just got a lot easier thanks guys
11-23-2011, 05:50 PM | #7 |
Re: Winter Time
I replaced the heater core on both my 72 GMC and 69 C-10 and didn't have to remove the hood or the fender well. Maybe I was lucky but both came out no problem.
Posted via Mobile Device |
11-23-2011, 06:27 PM | #8 |
Grandpa in the rustmobile...
Re: Winter Time
I never had to remove inner fender either (unless it was out, i forgot) did have to loosen hood hinge
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-23-2011, 07:53 PM | #9 |
I am a Referee of life.
Re: Winter Time
Spray the heck out of the bolts with PB Blaster under the lip of the fender and under the battery box..They're probably OK being a Ca truck.You just need to drop it loose,no need to take it out.You'll probably need to replace the rubber gasket and the goo on the heater box.Check the fan blades and the fan motor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-23-2011, 08:07 PM | #10 |
Re: Winter Time
I fought mine for about a half hour, then took the 10 minutes to remove the inner fender well. Pretty simple fix. Took around an hour or so overall (not counting the wasted half hour).
Heat is a good thing, and a happy girlfriend is too.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
11-23-2011, 09:50 PM | #11 |
Re: Winter Time
i ended up taking the fender out. made the job a lot easier, plus with my air tools it took no time at all. i also found rust so im in need of reparing it. and since my engine bay is painted flat black i cleaned up the fender
11-23-2011, 11:13 PM | #12 |
Scrapper 1
Re: Winter Time
I did the same thing but i did take the hood off and the inner fender makes for me to work right on top of it and it took me 1 full day to clean and repaint rerun all the new heater control cables and Gaskets washed the outer cab sanded it and painted where needed and put the new controller back in.
Now you have to remember I bought all new Re pop parts for this heater nothing old was reused other then the housing. Now i oppeded to run the AC blower instead of the heater blower for one it blows faster and uses more amps But it will warm your truck up in a fast way got my cab up to 130 Degree's in 3 mins.I've always loved my heaters. But i like to do the full o0n job like redo the radiator thirmisstat and hoses and i even changed the fan clutch Now the I've stopped using the heater control box on NONE Air trucks do to i can control how fast the motor will turn plus the fan switch is easyer to replaced . Most people over look the heater core until it gets cold I use mine year round in the hot days it can really help to cool your truck down I'm working on a way to push it back in to the engine compartment during a Really hot day so i can keep my engine cool on the hard loaded days i run it. |
11-24-2011, 12:53 AM | #13 |
Re: Winter Time
yeah a couple days it got so hot my truck over heated but with the heater working that should fix that, i also insalled a shroud. i need to do a little repair on the box with some fiber glass to fix some minor cracks, my goal with this truck is to build it as cheaply as possible but make it look as nice as possible.
Did you have any rust where the fender well connects to the radiator support? |
11-24-2011, 04:54 PM | #14 |
Re: Winter Time
Man I got to get this done. Been looking at it for months now! I think I am going to unbolt the hood hinge and have a buddy hold it.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-24-2011, 06:56 PM | #15 |
Re: Winter Time
when i took mine off i didnt need to take the hinge off. taking the fender well off made it really easy too.
Tags |
heater core |
