Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 11-23-2011, 04:14 PM   #1
mbgmike
Brake kits-lines-components all 25% off
ALL POWER BRAKE BOOSTERS,CONVERSION KITS, S/STL LINE KITS,BRACKETS,VALVES,ROTORS,CALIPERS ARE ALL
25% OFF
Offer valid now through Monday 11/28/2011 midnight EST for online orders.
* Already discounted items (sets), Applies to in-stock items. EXCLUDED
T
for example firewall brake booster brackets only $19.95
GM style all brass disc disc or disc drum prop valves 30.00 each
GM style disc/disc proportioning valve. Chrome 32.00 each
Adjustable Proportioning valve. Black. $20.00 each
67-72 S/STL SWB BRAKE LINE KITS 209.00 A SET
mbgmike is offline
Old 11-25-2011, 07:20 PM   #2
scotts72heavyhalf
scotts72heavyhalf's Avatar
Re: Brake kits-lines-components all 25% off
Do you have a chrome porp valve that has a 1/2 and 9/16th port and the line kit? If so can I order one.
Scotts72C10
scotts72heavyhalf is offline
Old 11-25-2011, 09:15 PM   #3
mbgmike
Yes we do. they are $32.00 on sale lines are 5.00 for stainless and shipping is $8.00
You can paypal us at
mikesbumpandgrind@earthlink.net if you like
let me know if disc drum or disc disc
mbgmike is offline
Old 11-26-2011, 01:01 AM   #4
scotts72heavyhalf
MIke,
My 69C10 is front disc rear drum, I bought this set-up from a fellow board member, here is part of the add:
Master cylinder is dual reservoir, 1-1/8 inch bore, Corvette style with 1/2 inch and 9/16 inch ports on one side. Has been prepped and painted with Eastwood Brake Grey paint. Includes deep core metal insert for power applications, plus bench bleeder kit. No Prop valve included.
Do I will take the chrome one you have for my front disc/rear drum application, should I call you on Monday just to confirm?
Scotts72C10
Old 11-26-2011, 01:47 AM   #5
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Brake booster brackets include??? Colors??? Options...Just Main Firewall bracket mount or the angular bracket as well??? Thanks
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 11-26-2011, 11:50 AM   #6
mbgmike
MIke,
you can call today or monday. we are open today
mbgmike is offline
Old 11-26-2011, 11:53 AM   #7
mbgmike
what angular bracket are you asking about? I can send you picks of all of them.
mbgmike is offline
Closed Thread
