View Poll Results: How would you carry more fuel?
Get an aux tank 3 18.75%
Get a larger single tank. 13 81.25%
Just carry jerry cans fool! 0 0%
Voters: 16. You may not vote on this poll
Old 12-02-2011, 11:53 PM   #1
1leglance
Poll
Ok with my Suburbasarus project I have some options for extending the travel range between fuel stops.
Currently I have a factory 21gal tank (or something like that).
There is room to add an aux tank behind it or go with 1 or 2 saddle tanks along the frame.
I could also get a custom tank made that goes behind the rear axle in place of the factory tank and would net me around 40+ gals.
And just so you know I am not a fan of jerry cans.
My thoughts are that 2 tanks & 2 fill points gives me the option of having a known quality fuel tank and then always add suspect fuel to the other tank....such as when in Baja. That way if I have engine trouble I can switch tanks and see if that helps. Oh I am used to using valves and such to switch tanks.
Of course 1 big tank is simple, but it puts a lot of wgt in 1 place (behind the axle).
All thoughts welcome.
1leglance is offline   Reply With Quote
Old 12-04-2011, 12:42 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Poll
Sounds like you like multipul tanks..I went with the 37gal www.NWMP.com tank. The price has shoot too the roof over the years sence I bought mine but it's been a great tank. There is a facotry 31 gal GM tank you may beable to swap? I forget the year when GM moved from 21gal too 31?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-04-2011, 12:50 PM   #3
duallyjams
duallyjams's Avatar
Re: Poll
Two tanks just means more things that can go wrong . I changed from 2 tanks to just 1 .
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-04-2011, 04:29 PM   #4
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Poll
I would go with option 4. Swap to TBI fuel injection to help with durability, performance and fuel economy and at the same time swap in a ’87 –’91 Suburban tank which will provide more fuel capacity and already have an electric fuel pump in it to feed the TBI. I already mentioned my feelings of carburators. You just can't polish a turd
DirtyLarry is offline   Reply With Quote
Old 12-04-2011, 10:07 PM   #5
rayfinseats
Re: Poll
You lose some ground clearance and things with side tanks. And you can't add sliders. I thought about adding a marine tank at one time. Just a thought.
rayfinseats is offline   Reply With Quote
