Old 12-03-2011, 12:24 PM   #1
DBear
DBear's Avatar
NP208 Help
I am gonna look at a np208 today, and wanted to know how to check to see if it is in good condition, meaning the guts of it. It is not installed in a vehicle, so didn't know what to look for. Any thing particular to look for?
DBear is offline   Reply With Quote
Old 12-03-2011, 06:50 PM   #2
Psycho71
Psycho71's Avatar
Re: NP208 Help
Pull the top plug out of it and use your finger to check the slop in the chain. Without tearing into it that's about all you could do aside from cycling it through the selections and checking the functions.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 12-06-2011, 10:19 PM   #3
orbot
orbot's Avatar
Re: NP208 Help
Yep... turn the shaft and check for slop and get it in gears and inspect the sounds...
orbot is offline   Reply With Quote
