Old 04-23-2003, 03:42 PM   #1
bubbastrick
Unhappy Edelbrock 1406 problems
Hi folks:
I have a remanufactured Edelbrock 1406. It is replacing a worn out 1405. I did the swap, and now I have to have the pedal to the floor for it to even idle. I have checked for vacuum leaks, and I have the choke hooked up to a switched 12V source. I dont know what the problem could be.
I sent an email to Edelbrock today, and hopefully they will have a solution.
Let me know any ideas you have.
James
bubbastrick is offline   Reply With Quote
Old 04-23-2003, 05:21 PM   #2
bubbastrick
Lightbulb
Could this be a symptom of a float that is not set correctly? Maybe too low?
Gimme some ideas.
James Strickland
AS Computer Information Systems
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge”
~E.J. Potter
Old 04-23-2003, 05:48 PM   #3
marcuspboldt
Registered Abuser
marcuspboldt's Avatar
Can actually see that the choke is operating? does the choke plate it'self ever open up?
marcuspboldt is offline   Reply With Quote
Old 04-23-2003, 05:49 PM   #4
Jackal2k9
Jackal2k9's Avatar
isnt 1405 a 600 and 1406 a 750? whats the diff. is it choke/no choke? i thought it same same carbs but one without choke assembly.
Jackal2k9 is offline   Reply With Quote
Old 04-23-2003, 06:01 PM   #5
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
1405 is manual choke and 1406 is electric I believe...both are 600 i think too
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-23-2003, 06:47 PM   #6
67_SS396
Sounds like improper float levels to me.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
