Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-30-2011, 03:09 AM   #1
sanford66
sanford66's Avatar
Lightbulb Speaker Ideas?
I know this should be in the audio section but i thought i would get more replys here. I need some ideas for speakers for my 72 Custom Deluxe. The dash was cut when i bought the truck, has a cd player, and there are 2 miss-matched 6x9 speakers wired up just laying under the bench seat. The gas tank is still behind the seat so no room there. Just wanting to see if anyone has any ideas or could share what they have done [pics would be great]. My dad has every woodworking tool known to man, and i'm pretty handy with wood, so building some custom boxes would not be a problem. I have already googled this site and didn't find much help, i could have missed something though. Any ideas? Thanks, Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 12-30-2011, 04:47 AM   #2
xb9rguy
xb9rguy's Avatar
Re: Speaker Ideas?
Just a thought but has anybody tried one of these headliners with built in speakers or something similar with any success? http://www.lmctruck.com/icatalog/cb/full.aspx?Page=95 I've been wondering about this same issue sanford hopefully we get some helpful ideas!
Jeramy
CURRENTLY OWN,
72 c10 project/driver
2010 Kia Forte Koup SX daily driver
88 cherokee wheeler and dog hauler
2001 drz 400
Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles.
xb9rguy is offline   Reply With Quote
Old 12-30-2011, 05:26 AM   #3
sanford66
sanford66's Avatar
Re: Speaker Ideas?
xb9rguy, that is a thought but i have the factory headliner in my truck and don't realy want to install that one. I have a nice 300-watt amp that would work perfect with some good 6x9's that i have. I just need to figure out where and how to put the 6x9's for good sound quality. Joseph
Old 12-30-2011, 05:52 AM   #4
xb9rguy
xb9rguy's Avatar
Re: Speaker Ideas?
If mine had a head liner I wouldn't have even thought about this option and am still leary of it. The only other thing I have heard of or seen that isn't behind the bench seat are custom kick panel pods that you can make or buy.
Jeramy
CURRENTLY OWN,
2001 drz 400
Old 12-30-2011, 06:06 AM   #5
longbed67
longbed67's Avatar
Re: Speaker Ideas?
There is enough room under the seats for speakers esp if you have the tools to make an enclosed sealed box setup that could be bolted in so it doesnt rattle. A 6x9 doesnt need much air space to pack a punch with a 300 watt amp.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 12-30-2011, 11:35 AM   #6
pumpkin
pumpkin's Avatar
Re: Speaker Ideas?
Use small speakers from a suround sound home system. I have a sub and two small suround system speakers mounted on the windsheild pillars in my motorhome, it souds great. Bose systems are awsome, if you can pay the price. The speakers are small enough to mount under the dash, by the shoulder belt bolt holes, or where ever you want. I did a similar install in one of my Blazers, and used my I pod, connected to an EQ, and two amps for tunes. You almost couldn't see a thing, but the sound was great.
pumpkin is offline   Reply With Quote
Old 12-30-2011, 11:40 AM   #7
Rochlow
Re: Speaker Ideas?
My plan is to make fiberglass kick panels for a 6 1/2" and tweeter and a shallow mount sub and amp under the stock bench.
Rochlow is offline   Reply With Quote
Old 12-30-2011, 11:57 AM   #8
bollybib
bollybib's Avatar
Re: Speaker Ideas?
Here's what I did
http://67-72chevytrucks.com/vboard/s...5&postcount=58
http://67-72chevytrucks.com/vboard/s...7&postcount=59
The sound isn't top quality and it's echo-ey because of the cab acoustics, but it works and is good enough for me.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 12-30-2011, 12:59 PM   #9
eurospec1
eurospec1's Avatar
Re: Speaker Ideas?
Home speakers are 8 ohm, car speakers, and amps, are 4 ohm, so you are cutting the efficiency of any amplifier in your truck in half by using home speakers..
There are more then enough options out there to use proper car speakers, there's no reason to use home stuff that it is not designed for
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 12-30-2011, 01:25 PM   #10
Red68
Red68's Avatar
Re: Speaker Ideas?
In the audio section of the board there is a board member that sells a product that allows you to mount 6x9s in the back cab corners. But it requires the gas tank to be relocated from behind the seat. Not sure if he is still selling them.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 12-30-2011, 02:10 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Re: Speaker Ideas?
I think you'd be better off going with this set up as well.
I would only put 6x9s in the doors which means you'll have to cut a hole, but I wouldn't do that for a set that's miss-matched...so given I recommend buying another set, I would say ditch the 6x9s and go the component route...a decent set should match up well with a 300 watt amp.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-30-2011, 03:50 PM   #12
jimmydean
jimmydean's Avatar
Re: Speaker Ideas?
I put my 6.5 in custom kicks and the tweet in the door. My subs will be where the tank was.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-31-2011, 11:18 AM   #13
sanford66
sanford66's Avatar
Re: Speaker Ideas?
Thanks for the replys guys. I have seen the cab corner speaker mounts and that would be the way to go if the gas tank wasn't behind the seat. And i am for sure not going to cut the doors. I think some custom boxes under the seat would be the best bet, just have to do some more measuring. Again, thanks for the thoughts. Joseph
