Old 04-24-2003, 11:42 AM   #1
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Question Exhaust Gasket from header to ex.pipe
I am going to replace the paper gasket between my header and exhaust pipe coupler (triangle shape with three bolt holes). I am wondering if you have to use a flat gasket or if you can use a doughnut gasket like they use on ram horns? Those doughnut gaskets seem like they work good.
I got a set of these thin copper flat gaskets I am thinking about trying to seal the suckers up. Are those good to use? If not I'll take them back because they were a little pricey. I'm just tired of hearing and smelling the exhaust leak!
Thanks everyone!
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 04-24-2003, 01:44 PM   #2
71Chev
71Chev's Avatar
Use the copper or aluminum. I used aluminum, and my flanges are bent at each bolt hole. They sealed up great. Should never have to buy any more header collector gaskets!
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-24-2003, 01:46 PM   #3
Long Knight
Thanks 71Chev
Long Knight
Old 04-24-2003, 11:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'll second the dead soft alluminum ones.
I am running the same ones I bought fro an other truck with differant headrs...they been removed and installed so many times it is unreal...and still no leaks.
Old 04-25-2003, 07:18 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Lightbulb
No need to buy expensive gaskets. If you goop on some RTV on both sides of those paper type gaskets, then bolt it up you won't have anymore leaks and it won't blow out.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
