cracked frame
found crack in frame today, drivers side engine mount hole. where else are these frames prone to cracks? can i just weld this crack or should i plate and weld?
![]() Join Date: Feb 2001
Re: cracked frame
TTT for you ...
Oh yes ... ![]() ![]() ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: cracked frame
I dont know about the 67-72's, but its a common problem on 73-87 frames near the steering box, at least on 4x4's
Re: cracked frame
I say weld up the crack. Some say that the crack won't reappear there but along side or next to the old crack. I have not found this to be true
Re: cracked frame
Depends on where it is and how extensive it is. In general, find the place where the crack stops, drill a small hole in the end of the crack to "stop" it (1/8 - 3/16), weld up the crack. Plating the cracked area won't hurt a thing, do it if you want.
