01-03-2012, 03:55 PM | #1 |
NPT to Inverted Flare?
I am having trouble finding something to mate 3/8" NPT male to a 3/8 Male Inverted flare. I am wondering if the NPT side would just work with a plain ole inverted flare union?
I am just trying to get from http://www.summitracing.com/parts/AER-FBM2618/ to the male end of a 3/8 steel inverted fuel line. Suggestions?
www.tomthetruck.blogspot.com <-- Aka build thread. Last edited by Tmwoodall; 01-03-2012 at 03:57 PM. Reason: Grammar |
01-03-2012, 04:13 PM | #2 |
Re: NPT to Inverted Flare?
speedway motors has those fittings in a variety of angeles
01-03-2012, 04:22 PM | #3 |
I'm seeing the same not quite perfect options that Summit has. NPT - NPT and AN - NPT but nothing for inverted flare - NPT
www.tomthetruck.blogspot.com <-- Aka build thread. |
01-03-2012, 06:05 PM | #4 |
i say again speedway motors does
01-03-2012, 06:48 PM | #5 |
Man, I must be dense, but this is as close as Speedway seems to get as far as I can tell: 3/8 IFF to 1/8 NPT coupler.
01-03-2012, 06:48 PM | #6 |
Normal brass fittings at your local part store should do it. You may need to use 2 , 3/8 npt female to 3/8 npt female , than a 3/8 npt male to 3/8 inverted female , but it will work. Just find the oldest store in town , go to the guy who answers all the questions , he should rattle the numbers off like nothing.
01-03-2012, 06:50 PM | #7 | |
Thanks.
01-03-2012, 06:52 PM | #8 |
what are you trying to adapt?
01-03-2012, 06:55 PM | #9 |
Stupid Holley Fuel pump has 1/4" (4 AN) female fittings, need it to go up to a 3/8" female inverted for my fuel line to plug into (Male end on fuel line).
01-03-2012, 07:11 PM | #10 |
I could be wrong , but holley pump should be 1/4 npt , or 3/8 npt , and I could rattle these part numbers off for the adapters you need (I am that old useless parts guy that trys to answer everything).
01-03-2012, 07:29 PM | #11 | |
01-03-2012, 09:26 PM | #12 |
the weatherhead number should be 202x6 for straight ,402x6 for 90 degree, Im at home now so that is just a guess , any good part store should be able to figure it out . hope this helps -Bob
01-03-2012, 09:28 PM | #13 |
Thanks, Bob. I was just on Jegs looking at the part I needed. I got so focused on using the first adaptor I listed above that I totally forgot that I could just go straight from the pump to the line with a pretty common adaptor and skip that other piece (which I was picking up to mate with my Edlebrock braided fuel line).
01-03-2012, 09:38 PM | #14 |
Fun With Fittings (interesting thread)
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
