![]() Join Date: Sep 2006
PS Hoses
It's probably been addressed before but, I'm running a '92 serpentine set up on my '68. What do I need in way of power steering hoses? Will I have to get them special made or will something out there work? Thanks.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
Re: PS Hoses
The serpentine pumps use an o-ring fitting for the hose that's screwed into the pump. Older pumps use an inverted flare fitting. Assuming you want to use 68 hoses, get an inverted flare fitting and replace the o-ring fitting.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I am a Referee of life.
Re: PS Hoses
The pressure hose screws into a large(1 1/8 IIRC) fitting on the back of the pump.I removed it and put the one with proper fitting threads in it.The routing of the hoses sucks (original later model hoses) until I can get some made but it works.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: PS Hoses
I guess I should have mentioned too that currently I only have the set of hoses off of the '92. I don't want to use them because they have this extra line that ran back up into the frame rails for cooling I guess. So, whatever it is, I'll have to buy.
