Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-15-2012, 12:28 AM   #1
BCOWANWHEELS
Th400 u-joint size ????
Can somebody tell me what size u-joint came stock in a big block truck with a th400 trans ? 1310 or 1350
thanks
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 01-15-2012, 12:34 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Th400 u-joint size ????
More than likely 1350, but here is a link to the measurements.
http://www.driveshaftspecialist.com/...D%20Guide.html
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-15-2012, 12:36 AM   #3
BCOWANWHEELS
i dont have a shaft to measure off of.
Old 01-15-2012, 07:53 PM   #4
mr48chev
mr48chev's Avatar
The U joint is going to have to be matched to the yoke and driveshaft you use. If you have the yoke you can figure out what it takes by taking a couple of measurements and comparing them to a u joint size chart.
Note: the chart USMCChevy gave seems a lot easier to use than the one I gave below.
This site gives you the dimensions and parts numbers for Spicer U joints. Get the Spicer number and you can cross it at any parts house but the Spicer brand U joints are worth hunting down. http://www.mdsdriveshaft.com/spicer_...sal_joints.htm
You also need to know if your yoke and driveshaft have inside or outside snap rings. Preferably both pieces will have matching snap rings or it takes an extra cost U joint most of the time.
Old 01-16-2012, 02:42 AM   #5
BCOWANWHEELS
guys i need to know what gm installed in "stock" bbc th400 drive lines.......
Old 01-16-2012, 08:20 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Different sizes for different years, one or 2 piece shafts, car or truck., slip yoke or bolt on yoke. Which 400 are you asking about? Could be either 1310 1330 or 1350.
dwcsr is offline   Reply With Quote
Old 01-20-2012, 05:54 PM   #7
puppy
puppy's Avatar
All are 1350 that I have dealt with
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
Old 01-20-2012, 09:17 PM   #8
BCOWANWHEELS
Thanks, i got me a new 1350 slip yoke for the trans and a good 1350 drive shaft and new precission u-joints. Now its time to decide on what rear axle i,am gonna run. Sstock 12 bolt, 9" ford or dana 60. Leanning towards the 60 as i have a power lok for it.
Old 07-01-2012, 09:13 PM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
the dana 60 would be my first choice
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
