looking for a carb
looking for a used holley 750 or 800 double pumper.
i have a used 750 eldenbrock with low useage for trade. i have to much cam for the vacum secondarys.
69 chevy short wide box project 70 GMC jimmy project Last edited by Johns70; 04-26-2003 at 04:16 PM. |
http://www.tpcracing.com/ mine is the red double pumper..he does great work and is very friendly..Yell Ty I sent you
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
ttt
69 chevy short wide box project 70 GMC jimmy project |
Used to have a truck
I've run some pretty radical cams with vacuum secondaries as in up into the 305 advertised duration range with just a little tuning on the secondaries. AFB's arent my favorite carb for other reasons but the secondaries are certainly tuneable for low vacuum cams. I ran one on a 351 cleveland that wouldnt pull more than 10 inches of vacuum and the secondaries on it it ran just fine at WOT . All it takes is a little fine tuning of the secondary counterweight . They used them on 426 hemis for Gods sake and those things had minimal vacuum at at anything over idle . There a couple of good books on Carter tuning that go into detail on the subject. Theyre cheaper than rebuilding a holley and if you like the carter ( weber, edelbrock , carter...whatever ) otherwise you might as well run with it.
No truck :-( |
ttt
