Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-03-2012, 05:45 PM   #1
richard2717
Equal opportunity joke ofender
richard2717's Avatar
71' Blazer Rust bucket build
Well here goes......
I have put the 68' panel on hold after buying this Blazer. I feel since i have been out of the auto body business for the last 15 years I would give the Blazer a shot before messing with the panel. I found the truck on Craigs List a few months back and did not look real close at it before buying it. I knew it had some rust issues but was not quite prepared for what I pulled out of it today. Original intention was to buy the truck to part out but after I got it home and started looking at it ........sitting in it........looking at it some more, over and over I decided I wanted to save it instead. I must have more money than brains but that is my intention so far. Here are some pictures of it like I bought it.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 02-03-2012, 05:48 PM   #2
richard2717
Re: 71' Blazer Rust bucket build
The previous owner removed the rear seat and installed 2nd Gen Blazer seats up front but it still has the original center console
Members I have met.
Old 02-03-2012, 05:51 PM   #3
richard2717
Today I decided to start ripping the interior out so that i could see just how much rot there was in the floor areas.
Members I have met.
Old 02-03-2012, 05:55 PM   #4
richard2717
The PO had placed a sheet of 1/2" plywood on the floor with carpet pad on top of that. Then they wrapped the entire floor, side walls and front floor in a black cloth. Needless to say with the leaks from the rear hatch and holes in the floor the plywood was not in real good shape.
Members I have met.
Old 02-03-2012, 06:09 PM   #5
richard2717
As I was cleaning up the plywood mulch I noticed a lot of mud built up around the whell wells. I was like man gotta get that mess out so it can dry up then I can see how bad it really is. Well I did not have to wait, cause once I hauled my fat butt up in I realized hey, that ain't dirt thats BONDO.....WTF? Big screwdriver and hammer after about 10 minutes and this is what is really there........OH NO......
Members I have met.
Old 02-03-2012, 06:13 PM   #6
richard2717
Here are the after shots
Members I have met.
Old 02-03-2012, 06:14 PM   #7
richard2717
I assume at one time he must have had a problem with the gas tank
Members I have met.
Old 02-03-2012, 06:22 PM   #8
richard2717
And...... I am almost certain he was a commercial roofer. I thought is was more bondo across the rear floor sill but it was actually aluminum tape with mastic material on it. Some places come up easy where they taped over dirt and grease but other cleaner areas are proving to be quite difficult to get off. The last picture is some of the bondo and roofing caulk that was pulled out from around the wheel wells, it was just heaped into the top of the cross bracing as well. The 2nd picture was a patch they made out of aluminum roofing metal and it was severely corroded.
Members I have met.
Old 02-03-2012, 06:22 PM   #9
68panelman
68panelman's Avatar
I'm in on this one. I feel for ya man!!!
68panelman is offline   Reply With Quote
Old 02-03-2012, 06:30 PM   #10
richard2717
Looks like I am going to need some rear floor sections worse than I thought. The floor flanges are also gone on the wheel tubs so will need them as well. I assume they are same as pickups so should not be to hard to find them. good thing is when I tore the side boxes out of the rear I found a stash of some goodies. Misc. hatch hinges and hardware, K5 emblems Stainless sill plates, Extra hoses and belts and the missing black visors from the front. I did not realize the tops of the cabinets were made to come off.
Members I have met.
Old 02-03-2012, 06:39 PM   #11
richard2717
Then I moved to the front floor area.....not much better but I have seen worse. The seats appear to be out of a 2nd gen Blazer because of the poor attempt at making the brackets work. I had to take a picture of the Pass side rear hold down because of the way it was mounted. PO had used spacers to lift it up off of the floor to compensate for the angle of the seat being off I suppose. After I removed the two bolts that were holding the front of the seat ( supposed to be four buts whos looking right) and removed the seat out of the truck, I started removing the rear hold down you will have to look at the pictures to see what the spacers were. ( and yes they are Sears brand LOL)
Members I have met.
Old 02-03-2012, 06:43 PM   #12
richard2717
I cant find the picture of the driver side seat but PO installed a wooden 1x4 across the back of the seat bracket to kick it upand be able to use factory mounting holes. As if that was not bad enough once I moved the floor covering out of the way, what else did I find???? not to be outdone with the sockets on the pass side they used two nice Sears screwdrivers to shim the wood up and left them. I am hoping at the rate I am finding tools I may need to go get another box.
Members I have met.
Old 02-03-2012, 06:45 PM   #13
richard2717
Thanks man, I got my work cut out for me but I think it will be worth it in the end.
Richard
Members I have met.
Old 02-03-2012, 06:47 PM   #14
richard2717
I am still looking for a rear floor even if it is smaller sections. I could also use wheel wells and the inner 1/4 panel sections that the tubs bolt to
Richard
Members I have met.
Old 02-03-2012, 08:53 PM   #15
rsavage
rsavage's Avatar
Subscribed. Good thing you are a body guy. Glad you are saving it. It will be worth it in the end.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-03-2012, 10:06 PM   #16
richard2717
Thanks. Nowadays I call myself a signman instead of a bodyman so i think i will make me up a sign that says
KEEP AT IT
IT WILL BE
WORTH IT
and place it in the wall once I get the truck in the garage.
Members I have met.
Old 02-03-2012, 10:22 PM   #17
Ridnhi
Ridnhi's Avatar
I'm glad that you are saving it too. I hate to see them forgotten about or even worse, junked. I'll definitely follow this one, I'm most interested in watching your inner/outer rocker replacement.
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 02-04-2012, 12:49 AM   #18
richard2717
Well this will be my first experience with the rocker boxes but I have doen several pickup floors in the past so hopefully everything will go pretty smooth.
Richard
Members I have met.
Old 02-04-2012, 02:44 PM   #19
richard2717
Here are some pictures of the front floor area and rocker area. I will be ordering the few parts I dont already have in the next few days so I can get started. Looks like its going to be a fun project. I have also decided to take the 68' clip off of the panel truck and put on this one. It needs a little work but not as much as the 71' clip, and I like the 68' style better anyway.
Members I have met.
Old 02-04-2012, 02:48 PM   #20
richard2717
Helps when you attach the pictures The pass rocker was only held on with 2 screws neat the top. One front one back. That was the only place avaulible with metal behind it.
Members I have met.
Old 02-04-2012, 02:53 PM   #21
richard2717
If you notice in the last picture above you can see the PO attemted to weld in some angle and flat bar bracing. Must have been 1st time with a mig. I pulled it all apart by hand. ZERO penetration on the welds.
The last picture shows the DS B pillar area. I am almost positive that it will not look any better once I start digging. More likely it will look like the pass. side.
Members I have met.
Old 02-04-2012, 06:40 PM   #22
68panelman
68panelman's Avatar
Originally Posted by richard2717 View Post
thanks man, i got my work cut out for me but i think it will be worth it in the end.
Richard
absolutely!!!
Old 02-04-2012, 09:01 PM   #23
warbucket
warbucket's Avatar
Looks like mine, I just finished up the front floors and boxes and I can't believe I got all that done. Keep at it. Subscribed
warbucket is offline   Reply With Quote
Old 02-04-2012, 09:24 PM   #24
Ridnhi
Ridnhi's Avatar
It is amazing what some people are completely ok with doing to "fix" their cars or trucks. I guess they feel that if the surface looks ok then everything is done right. I'm glad you are tearing into it. I had a "professional" body man, I use that term loosely, fix mine and I have ended up tearing it all apart to find they covered problems up.
Old 02-04-2012, 10:08 PM   #25
richard2717
Ridni,
I learned years ago that the majority of the time only I am willing to take my projects as far as they need to go. Most shops around here basically want to get it covered and out the door.
Warbucket
thanks for the extra parts you had. They will get used. I could still use some floor pans and rear. Wheel tubs
Richard
Members I have met.
