Old 02-07-2012, 11:58 PM   #1
wwj75c30
wwj75c30's Avatar
dodge dana 44 on a c30?
i bought a dana 44 out of a dodge d250 its all there with springs and all steering stuff.
would it work under my 75 c30? since its the same lug pattern it wont be offroaded very hard
wwj75c30 is offline   Reply With Quote
Old 02-08-2012, 12:16 AM   #2
wwj75c30
wwj75c30's Avatar
Re: dodge dana 44 on a c30?
and im going to use dually hub spacers so i dont have to buy new wheels
Old 02-08-2012, 03:13 AM   #3
ghettoluxury
ghettoluxury's Avatar
Sounds good, the only thing to watch out for is that the spring pad width for Dodge is 1/2" wider than Chevy.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-08-2012, 03:19 AM   #4
wwj75c30
wwj75c30's Avatar
so could i just weld on new spring perches 1/2" closer in? and the steering will still work with stock 2wd steering box?
Old 02-09-2012, 09:53 AM   #5
I'm confused. Is the Dana 44 a front axle? Do you have a C30 or a K30? If it's a C30,is it converted to 4wd? If it's converted to 4wd,do you have crossover steering? Is that why you have a 2wd steering box? Because a 2wd steering box won't even work in a stock 4wd. As far as a Dodge axle into a GM goes,the spring pads need to be moved inward. If you are in the process of converting a 2wd into a 4wd you could probably set it up so the springs are spaced for the Dodge axle,if it's all custom anyway.
Old 02-09-2012, 11:16 AM   #6
CrewCab59
CrewCab59's Avatar
The dodge D250 and D350 series were 2wd.
The dodge W250 and W350 series were 4wd.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-09-2012, 11:35 AM   #7
mknittle
mknittle's Avatar
all you need would be 1/4" on a side The spring perches on the differential side are machined into the housing. so If it were mine I would make some plates to weld on top of the existing perches with the hole spacing that you want.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 02-10-2012, 02:51 AM   #8
wwj75c30
wwj75c30's Avatar
its a front axle and im gonna be converting it soon
and itll be all custom i just need the money
Old 02-10-2012, 02:52 AM   #9
wwj75c30
wwj75c30's Avatar
and i meant w250 i always forget about the d series and w
Old 02-10-2012, 08:22 AM   #10
andrewmp6
Yeah you can cut the spring perches off and weld new ones on in the right place.But if you want a big lift or big tires i would look for a dana 60.
andrewmp6 is offline   Reply With Quote
Old 02-10-2012, 08:42 AM   #11
Ok,the leave the axle alone and just mount the spring hangers where they need to be. No sense in altering the axle when you have to fab/install spring hangers anyway. And,I know what you mean about money.
Old 02-10-2012, 10:00 AM   #12
Mattman2010
Mattman2010's Avatar
Just mount the axle up. The half inch difference doesn't not effect anything. I know dieselwrencher has done this with a dodge d60 and it is fine. I have also read about other people that did this as well. It will bolt right in.
I forgot you are converting the truck to 4x4 If your going to build the mounts then work in the half inch. But if you just steal parts off a 4x4 to convert it then don't worry about the half inch.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 02-11-2012, 06:01 PM   #13
wwj75c30
wwj75c30's Avatar
so it should be fine?
Old 02-11-2012, 06:47 PM   #14
Mattman2010
If you use stock 4x4 brackets it will be fine. If you build your own brackets then you might as well add in that half inch.
Build Thread
Build Thread
Thread
Old 02-12-2012, 06:47 PM   #15
wwj75c30
wwj75c30's Avatar
oh ok i was just gonna make my own
Old 02-13-2012, 01:17 PM   #16
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
amazing what a jack or a come along will do to position for that extra 1/2"...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-13-2012, 06:02 PM   #17
argonaut
argonaut's Avatar
Yikes!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-13-2012, 06:10 PM   #18
wwj75c30
wwj75c30's Avatar
what you mean?
Old 02-13-2012, 10:11 PM   #19
ghettoluxury
what you mean?
If you use factory 4x4 setup most guys including myself don't worry about the extra 1/2". We simply bolt one side up and then put a port-a-power or bottle jack between the springs and spread them until the center pin on the other side drops into the pad. Then tighten down the U bolts and release the pressure from the jack. This is the redneck way to use a Dodge front axle in a Chevy.
Old 02-14-2012, 02:02 AM   #20
wwj75c30
wwj75c30's Avatar
oh ok cool. i might be changing my plans tho this guy wants to sell me his 77blazer with 3/4 ton running gear for $600 could i use it? i wanna swap to srw i found a clean bed and tailgate for $100
Old 02-16-2012, 12:03 AM   #21
ghettoluxury
Yes you can everything will swap over.
Old 02-17-2012, 11:15 AM   #22
Yeah,that'll work and much better. When spreading GM springs to fit a Dodge axle you can only "hope" the axle sits centered.
Old 02-18-2012, 05:25 PM   #23
wwj75c30
wwj75c30's Avatar
well no blazer for me. couldnt get the money. im thinking just buy stock mounts and a chevy axle or just save up and buy a k20 or k30
