Old 02-10-2012, 07:54 PM   #1
odog
odog's Avatar
Spring pads
I need to buy new spring pads for my new axle. The pads that the leaf springs sit on. I am putting in a 3/4 ton axle out of a 76 chevy and the pads are 42 1/2 inches on center and I need 40 1/2 inches, so I have to cut the old ones off and weld on new ones. Problem is, the old ones are cast iron and I am not doing a very good job of saving them when I am cutting them off. Does anybody know where I can get a new set of spring pads, preferably stamed steel, cause its easier to weld on than cast is. I guess I may need shock mounts as well.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 02-10-2012, 08:09 PM   #2
vectorit
What?
vectorit's Avatar
Re: Spring pads
Quick Google turned up some at Summit.
http://www.summitracing.com/search/P...pring-Perches/
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-10-2012, 08:13 PM   #3
vectorit
What?
vectorit's Avatar
Re: Spring pads
diy4x will most likely have everything you need too.
http://diy4x.com/cart/index.php?rout...product_id=123
Shock tabs
http://diy4x.com/cart/index.php?rout...product_id=134
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-10-2012, 08:18 PM   #4
odog
odog's Avatar
Re: Spring pads
I think I found some on evilbay, ther are for a 3.5 inch tube, and are 6 1/2 inches long. mine measures 3.4 with my calipers, and 5 inches long. They are for a Dana 70, and I'm pretty sure mine is a 14 bolt, if not its a dana 60, either way its not a 70. I think they should fit. I checked out the summit ones, one for a 3.5 inch tube, but it was 7 inches long. Not sure if the lenght matters a whole lot.
1969 4x4
Old 02-11-2012, 12:03 PM   #5
OldCreek
OldCreek's Avatar
Re: Spring pads
Go diy4x...they're great!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-11-2012, 07:59 PM   #6
78K20
78K20's Avatar
Re: Spring pads
Take your time when welding on that axle tube, so as not
to cause any warpage.
78K20 350 / 400TH 3:73's, Dual Polly tanks, my old plow Trk. Now parting out.
84K20 6.2 "J" Code Diesel / 700R / 4:10's
78K20 454/400TH 3:73's Dual tanks (my new plow rig)
78K20 is offline   Reply With Quote
Old 02-12-2012, 10:48 PM   #7
Mr. 250r
Mr. 250r's Avatar
Re: Spring pads
Get these http://www.ballisticfabrication.com/...ch_p_1485.html they have different sizes and 3 holes for different setups middle being a stock setup i used them on my 05 FF swap http://67-72chevytrucks.com/vboard/s...d.php?t=481550, as far as welding like 78K20 said be careful i tack welded them in place let it cool for a bit then welded one bead on one side then switched and did the other side only one bead and let it cool for awhile because the tubes do get warm and i think they're only 1.5in the tack welds kept them from pulling up on the other side, and as you can tell there's a restart on one of them which i do not prefer but since mine was in the truck i didn't feel like taking it out but if you can just get a mig welder and weld them vertically down it will lay flat be easier look nicer and hold fine
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 02-13-2012, 12:38 AM   #8
odog
odog's Avatar
Re: Spring pads
Yeah I have been thinking about the welding. I dont want to warp the tubes, I have a mig at the shop, I think I will tack both sides like Mr. 205 said. I think I may weld half of one side, switch sides, do half, then go back and weld the other halves. Just to keep the heat down.
1969 4x4
Old 02-13-2012, 06:20 AM   #9
argonaut
argonaut's Avatar
Re: Spring pads
I got mine from DIY4X also.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-13-2012, 12:36 PM   #10
coops714x4
coops714x4's Avatar
Re: Spring pads
Also make sure you keep the pinion angle right, even a small change can do some BIG damage. Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
