02-13-2012, 05:08 PM | #1 |
headers don't fit?
Hey Guys,
I need some help... I just bought a 65 c10 with 250 ci inline 6cly... the truck came with a set of tube headers and a offenhauser 4bbl manifold... they were not installed so my first job has been to put them on. The problem I'm having is that the three tubes that go to the front half of the motor seem to run right into the the motor mount when I try to install them. The other group of tubes that feed from the rear of the motor seem to fit OK. Has anyone else had this problem? Did chevy put the motor mount in a different location on different size engines? Do I need to remove the motor mount, put on the headers and then reinstall the motor mount? I THANK YOU FOR ANY HELP OR SUGGESTIONS! Lars |
02-13-2012, 07:18 PM | #2 | |
Re: headers don't fit?
02-13-2012, 07:35 PM | #3 |
i had long tube headers on my 68 panel truck with 250 six and everything cleared fine. pretty much same frame. did you try switching headers front to back?
02-13-2012, 08:28 PM | #4 |
Yea, I've tried every combination I can think of, I guess I'll take off the motor mount... but I really can't see how it will fit under there. Thanks for the suggestion.
Lars |
02-13-2012, 11:24 PM | #5 |
Maybe it's a 292 that someone dropped in? They are a little taller, maybe that's why it doesn't fit?
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
02-14-2012, 02:09 AM | #6 |
Hey, I only know that the previous owner said the engine is a 250... But I don't know what it is for sure.... how am I gonna find out what engine it is? Thanks
Lars |
02-14-2012, 07:25 AM | #7 |
The quickest way I know is the position of the fuel pump. On the 292 it is further back on the engine than the 250. As you can also see, the 292 has much taller side plates.
02-14-2012, 09:28 AM | #8 |
the 230, 250 & 292 header should be the same
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-14-2012, 08:03 PM | #9 |
Thanks to all for your help! I'm gonna look at my engine and figure out which one I have? I think I'll need to modify the engine mount or buy new headers.
Lars |
02-14-2012, 10:54 PM | #10 |
I have heard that they do not make the long tube headers for the 292 (one of Stacey David's shows ....Gears I think). I'd say the taller deck height would cause the tubes to hit if they were a set from a 250.
All theory in my part as I have never had a 292.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-15-2012 at 08:16 AM. |
02-15-2012, 02:07 AM | #11 |
it must be a 292 another way to tell is if your motor mounts are not directly across from each other the 292 motor mounts are offset as opposed to the 250 and 230. I have long tube headers on my truck and there are no clearance issues at all.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-15-2012, 10:46 AM | #12 |
Here's a set of headers that do bolt on. Look good. Don't rot out and are quiet.
http://stoveboltengineco.com/catalog...roduct=1395980 |
02-15-2012, 03:08 PM | #13 |
Yea, I'm just being a tightwad, I'm just gonna have to bust loose with the cash and buy a good set.
02-19-2012, 10:17 PM | #14 |
I had headman headers on the I6 in my 65 and they fit really tight up against the back of the engine munt. I think I remember needing to hammer a bit to make fit, the front one always laid up against the engine mount when installed.
Posted via Mobile Device |
09-30-2012, 07:09 PM | #15 |
If they are the cheap "flow tech" ones from jegs or summit (part 11530 I think) they are for a 4wd and do not fit a 2wd without modification. The height of the frame comes in to play on the two different drive lines.
1977 Chevy C10 RWD long bed |
10-04-2012, 12:55 PM | #16 |
you need to remove the rear u shaped mount to put the rear one on and use some wedging to get the front on i did this with my flowtechs i installed on my 230 what you do is unbolt that mount and it slides out of the tube and re install once you have both headers on
Tags |
65 headers don't fit, headers 250 |
