Old 02-13-2012, 07:12 PM   #1
VWNate1
VWNate1's Avatar
Question Folding Bench Seat for '69 C/10 ?
O.K. , I tried the search engine and didn't find anything .
I need a folding backrest stock bench seat for my '69 C/10 , before I go buy the wrong one from a '72 , do they all interchange from '67 ! '72 ? .
I hope to buy a good used folding bench and have it re covered, they
re really cheap in all the scrap yards once the covers are gone .
Don't waste time telling me to simply remove the rear most side bolt on each backrest support , that's not going to work , I read that B.S. here before and took my nice original seat apart , I need a true folder with a pivot , not junk .
TIA ,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 02-13-2012, 08:58 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Folding Bench Seat for '69 C/10 ?
No B.S. here. The only stock fold down back seats I have seen were from a '67 or early '68.
Hope this helps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-13-2012, 10:10 PM   #3
69C-owner
hmm didnt know they made them but I'm guessing all 6 years had the same bolt pattern for the seat mounts so if you find one thats in a 67-72 then id say it will fit in your 69 but dont hold me to that
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 02-13-2012, 10:16 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
I thought they were all folding, since the gas tank is behind there. I bought mine from a local guy but idk what year it's out of.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 02-13-2012, 10:25 PM   #5
leddzepp
Moderator
leddzepp's Avatar
All 67-72 bench seats will interchange, as they have the same mounting brackets. I have found the only ones that fold forward however have been out of 67-68 trucks. And you are right, there are a ton of them at the junkyards here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-14-2012, 02:26 PM   #6
Classic Bowties
Always on the hunt...
Originally Posted by VWNate1 View Post
O.K. , I tried the search engine and didn't find anything . I need a folding backrest stock bench seat for my '69 C/10 , before I go buy the wrong one from a '72 , do they all interchange from '67 ! '72 ? .
As shyguy and ledd have already stated above, look for an original bench out of a 67 or 68.
Ledd, that first part is true as they all used the same overall mounting footprint, but on that second part it should be noted that the lower bench frames and bench mounting bracket & track height changed between 67-72 at least twice if not three times (I would need to dig around a bit to confirm a third). Mel
Classic Bowties is offline   Reply With Quote
Old 02-14-2012, 02:40 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Thanks for the clarification Mel. I know the brackets themselves had some differences, but I just wanted to get the point across that all bench brackets will bolt to the floor regardless of the year. If you have a pic depicting the differences, that would be awesome info.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-14-2012, 02:58 PM   #8
VWNate1
VWNate1's Avatar
Thumbs up Re : THANK YOU !
As I don't see many '67 /'68's in my local yards , I'll just keep an eye out ~
I looked at those nice repop original typ covers and have decided to custom rebuild me a nice rock hard one , I have a broken back so a firm seat , no foam , is very important .
I'll get on the search , anyone in the So. Cal. area who spots one in a Pick-A-part give me a shout and I'll grab it .
My '76 GMC came with the ridgid backrest , I found an '83 with the folder and grabbed it , the floor mounts were the same so that was possibly the best $35 I spent on that truck .
Again , THANK YOU for the help ! I'm a dedicated InLiner guy so I hope I can return the help , I can tune these old beasts to run very sweetly indeed .
-Nate
Geezer
Old 02-14-2012, 06:11 PM   #9
Baggerjohn
Baggerjohn's Avatar
I'm taking out a seat like you're describing out of my 67. It's in fairly good condition. Hopefully I will have it out in the next two weeks. It is black. Has a tear along the seam on drivers side. Other than that, it's all good. I'm in Huntington Beach if you care to see it.
"Arrive, Raise Hell, Create Confusion, Leave".
Baggerjohn is offline   Reply With Quote
Old 02-14-2012, 06:43 PM   #10
1972RedNeck
1972RedNeck's Avatar
The '67 seat I have has springs and foam in the back. Could you get a full foam seat in '67?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-14-2012, 08:07 PM   #11
VWNate1
VWNate1's Avatar
Post Re : Folding Bench Seat for '69 C/10 ?
YES PLEASE ! .
Ping me off list to arrange this please : VWNate1 (at) yahoo,com .
THANX !
-Nate
Geezer
Old 02-15-2012, 02:28 PM   #12
_Ogre
_Ogre's Avatar
nate good to see you over here.
lot's of activity on this forum.
hope you found a new home here...
shop air compressor timer
Old 02-15-2012, 02:34 PM   #13
VWNate1
VWNate1's Avatar
Thumbs up Re : THANX !
Any time I find InLine enthusiasts , I'm home .
Seems like a good bunch here .
-Nate
Geezer
Old 02-15-2012, 06:56 PM   #14
lil hoodlum
lil hoodlum's Avatar
Nice looking truck!
Are those Texas plates on there? Looks like some Texas Registration and safety inspections stickers on the windshield also.
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
Old 02-16-2012, 12:31 PM   #15
VWNate1
VWNate1's Avatar
Thumbs up Re : My New Old Truck
Yes ~ this was a Ranch truck somewhere in TEXAS , I was unable to find any shortbed L6 powered trucks in So. Cal., prolly they all got Hot Rodded years back .
I found it in Dallas , bought it and drove it home via those wonderful two lane blacktop roads it was made to run , I love touring America in my oldies , I do not own a modern car or truck .
As the mechanicals are somewhat suspect , it took me nearly a whole case of oil to get it home but I'm working on sorting it out whilst continuing to drive , work and enjoy it very much ~ a typical GM product , it can be seriously neglected or abused and still be everything one ever wanted in a truck . that's why I'm a Bowtie Guy 'till I die ! .
The paint is actually rather weathered , I'm not sure what kinda wax they used but I wish I did ! . it looked terrific if suspect , as soon as that wax wore off , it looks like just another old truck .
I've only had it since August last year and already nearly 10,000 miles on it .
-Nate
Geezer
Old 02-16-2012, 03:33 PM   #16
lil hoodlum
Well I think you have a rather neat truck. I'm not the biggest fan of the wagon wheels but I think they look good on your truck.
Wow! A whole case of oil!?! Did you have any problems on the drive to California? I would be interested to hear about your trip home.
Thanks for sharing.
By the way, my seat is out of a 1968 GMC and it does fold forward. I may be incorrect but I believe all of the bench seats from 1967-1972 will fold forward if the wingnut(s) are removed. The bench seat covers from the 1969 and up usually have a covering over the mechanism that will allow the seat back to fold forward.
Old 02-16-2012, 04:05 PM   #17
VWNate1
VWNate1's Avatar
I rather like this truck , the cheapo 1970's vintage American Racing wagon wheels are scrap and will be gone soon , new tires and all .
I recently found an identical C/10 in a junkyard with the four original 15" steel wheels , I bought them , lucky me it was 1/2 price day so they were $14 each , including the worthless old tires they normally gouge you to either but or pay to have removed .
I sent the wheels off to the powder coater , they're white now as will be both bumpers ere long .
I got lucky and found the 5th stock wheel , for the spare , on a Task Force junker last week , it needs to be bead blasted then painted or powder coated , I have the new LT 28.2" O.D. tires on order , I can hardly wait to get them mounted up .
The trip was fun , as always I had daily tinkering to do , the same day I bought the rig I hit up various .99 Cent Stores and Pick 'N Saves , assembled a basic toolkit and got some lubricants in Foo-Foo cans as the door locks didn't work etc. apparently this old truck spent most of it's life just sitting out on the ranch before the goof ball bought it and proceeded to be mean to it ~ crappy Mechanical works by uncaring or perhaps vicious old rig haters , damaged quite a bit and nothing they did , was done correctly .
As far as I can tell , they installed a rebuilt short block after a rod went through the side of the block , the old head has terribly wobbly valve guides so it smokes a fair bit upon initial startup cold or hot plus smokes on trailing throttle but has zero blowby .
On another forum , I posted daily drive reports , I don't really do the blog thing but many know I'm a Journeyman Mechanic with a special affinity towards InLine engines , especially StoveBolts .
I have a 40 year habit of rescuing junk and driving it home , tinkering and having a swell time , all the way home .
I hope this will be the last ' keeper ' Shop Truck I ever buy as I'm not young anymore .
There ARE NO WINGNUTS on the seats of these trucks ! at least not in the '69 ~ '72 models , I've been checking every one I find in the yards . it has two fixed bolts at each side .
Hopefully Bagger John's seat will be what I need or at least give me the details I need to know .
Does anyone known why I can't post a classified ad ? I have a nice Muncie SM465 tranny for sale dirt cheap .
I'm pretty sure I posted an intro message detailing some of the fun I've had , look for it and ask there , I'll tell you all about the myriad troubles , issues and wrong / damaged parts I've had to fix already .
This is a GREAT TRUCK ! .
-Nate
Geezer
Old 02-16-2012, 04:22 PM   #18
leddzepp
Moderator
leddzepp's Avatar
In order to post any item for sale you must be a subscribing member. here is info on how to do that: http://67-72chevytrucks.com/vboard/payments.php
If that link does not work, click on "subscribe" near the top of this page, just under the search box
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-16-2012, 06:13 PM   #19
VWNate1
VWNate1's Avatar
Post Re: Folding Bench Seat for '69 C/10 ?
Thanx ! .
-Nate
Geezer
Old 03-27-2012, 04:27 PM   #20
VWNate1
VWNate1's Avatar
Post Re : Folding Bench Seat UPDATE
O-Kay then ;
Dano's Yard Sale set me up with a nice old '67 folding back rest bench seat , I took it to PerezAuto Trimmers in Pasadena (626) 700.7945 , he did a nice job of rebuilding it and I had him enclose the back part & add three large pockets to it so now I have a place for my map book , windshield sun shade , etc. etc. .
It's nice and firm too ~ just the thing for an old man's broken back .
I gave the old seat in VGC to ' 50BOMB ' , he's in Garden Grove if anyone would be so kind as to carry it down there to him....
-Nate
Geezer
Old 03-27-2012, 07:56 PM   #21
Red68
Red68's Avatar
I wanted a full foam seat (back and bottom) that also folded forward. Learned that it was not an option so I took my old spring back seat and found a full foam back seat cut the bottom part that hinges off my spring seat and welded on the foam back frame along with the stops. It is at the upholstery shop right now getting covered.
I'll post some pics when I get it back.
Kevin
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 03-28-2012, 09:34 AM   #22
VWNate1
VWNate1's Avatar
Sounds good ! .
Please remember to post pictures here when it's done , weather it turns out good or bad .
-Nate
Geezer
Old 03-28-2012, 12:14 PM   #23
RenoKeene
Florida Edition
RenoKeene's Avatar
I just wanted to say I think you are my kinda guy, not afraid to take on a "suicide mission" when it comes to these trucks. Put together a kit bag and hit the road. I think it's a lost art. I like your truck as much as any of the shiney big money trucks on here (including mine) and glad you joined this forum.
Brad
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-28-2012, 12:19 PM   #24
VWNate1
VWNate1's Avatar
Post Re : Road Trip
Who , me ? .
I'm just an old guy who loves old vehicles and being out on the road....
I've done this many times over ,my big brother usually waits until we're several states from home before telling me he neglected to check the air in the spare , or replace that leaky water pump etc.....
Being a Field mechanic since I was a child , makes this sort of thing fun for me ~ I get to see many places other miss and I meet all manner of nice people too .
If you were referring to some else , sorry I barged in .
-Nate
Geezer
Old 03-28-2012, 12:39 PM   #25
RenoKeene
Florida Edition
RenoKeene's Avatar
Yes, you Nate. I was talking about improvising, repairing on the fly and keep rolling. Not alot of us left who can jump into a rolling wreck with a bag of tools and actually make it to where we have to be, no matter what the road throws at us. My Dad loves the InLines especially the Roadmaster Straight 8.
