Old 02-17-2012, 02:00 PM   #1
Adams74Chevy
Adams74Chevy's Avatar
Will a floor trans jack work?
Will a floor trans jack work on a stock height '73 K20? I looks like that most I have found go from around 8"min. up to 24"max. I'd really just like to get a high lift trans. jack but working on a budget is the key right now.
Thanks,
Adam
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 02-17-2012, 04:52 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Will a floor trans jack work?
You should be good. My belly is at 24" on my 68 K20 lifted 4" on 35s, so you should be below the 24" maximum range of the standard jack. At the worst you could measure it, but I'm guessing if that was possible you would've done it.
I'm going to work on a buddies 84 K30 this afternoon and I'll measure the distance to the tranny and subtract for the 4" lift and 37s if you want one from your body style.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-17-2012, 06:14 PM   #3
Adams74Chevy
[QUOTE=lowrollin70gmc;5194708] At the worst you could measure it, but I'm guessing if that was possible you would've done it.
QUOTE]
I can but by the time I get home from work it's alread dark and then to get down in the muddy yard...I hoped somebody out there had tried and it worked or failed. I will probably measure tomorrow anyways. I'm hoping maybe I can work on it over the holiday weekend...but we'll see how far that gets.
Old 02-17-2012, 06:55 PM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
[quote=Adams74Chevy;5194821]
QUOTE]
I use a motorcycle jack from harbor freight. if it's too short, 6x6 wood blocks!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-17-2012, 10:57 PM   #5
lowrollin70gmc
Too many projects
I was just under a lifted K30 and taking in account that he is lifted 4" and runs 37s (another 4" over stock tires (29s), you should be fine. He measured 27" to the pan, so subtract 8 and you're looking at approx 19", which gives you some wiggle room with a 24" jack.
And at the worst throw a few 2x4s or 4x4 chunks and get that extra few inches.
Andrew
Old 02-18-2012, 02:14 AM   #6
OrrieG
OrrieG's Avatar
I have 74 K10 axles, tranny and transfer under mine. R&R with a 2.5 ton floor jack with no problems. Did have the cab off which made aligning it a little easier on the install.
OrrieG is offline   Reply With Quote
Old 02-18-2012, 03:34 AM   #7
andrewmp6
Or worse case flatten your tires it will lower the truck just enough.
andrewmp6 is offline   Reply With Quote
Old 02-20-2012, 09:42 PM   #8
Adams74Chevy
Yesterday I picked up the transmission floor jack...maybe next weekend I can use it. It will be nice to have the trans leak fixed and the mount replaced.
