What racing seat should i buy?
I'm installing a roll cage in my truck and need to install racing seat and I'm not sure what to buy, there are so many different seats out there. I want to go with a fixed back seat, I will be driving the truck on the street a little so I don't want something that is going to kill my back. I don't want to spend over $1700 for both seats. Anyone that is running a race seat that they like let me know?
Thanks Brett PS. I was looking at the Sparco and OMP seats just too many to pick from.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
![]() Join Date: Jun 2006
Re: What racing seat should i buy?
Which ever one you buy be sure it fits your butt. Squeezing in to a narrow seat gets uncomfortable real fast.
Kirky has some nice seats in different sizes that are reasonably priced. You should be able to get a pair with covers and mounts for less than $1000
I was looking for something a little cleaner looking. I still plane on going to car shows with the truck.
Couldn't you buy Recaro's for that kind of money.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Kirkeys. Then get whatever color cover you want.
Posted via Mobile Device |
I could not get the carbon fiber ones but I could get the fiberglass ones. I looked today and found all the nice fiberglass ones do not have holes in the backside of them to tie into the roll cage and to pass the nhra tech the back has to tie into the roll cage.
~Rest In Peace~
you regret getting a racing seat ,they get hotter than hell in summer IMO
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Have you looked at Corbeau seats?
I will look into them thanks.
Has anyone drilled into the back of there race seat to attach it to the cage?
Mini Truck Parts |
Get the kirkey seats you can get the pro drag seats with good harnesses and all tabs + mounting hardware for less than $1000. They are comfortable seats, not many can say that. Although I'm a little bias, I do own a set of these. Mine bolt through the backs, i I'd send you a pic, but the beast is in storage.
Hope I further confused you..... ![]() ![]() ![]() |
#13 | |
#14 |
#15 | |
#16 | |
It's Better With Nitro
#17 |
mini truck racer
X 2 on the JAZ . I had the Kirky in my last truck . I like the Jaz better .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#18 |
Thanks guys, I will look into the Jaz seats. I found I dealer around me that has a couple different seats in stock so I'm going to go and check them out.
#19 |
I ended up buying two of the Corbeau FX1's from a dealer around me.
Thanks for all the help guys.
#20 |
60-66 Nut
How about some pics when you get them installed?
#21 |
I will take some pictures but it won't be for a couple more months, I sill have a lot to do on the truck.
#22 |
What brackets r u going to use
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#23 |
I'm going to make my own brackets, I will know a little better once I get the seats.
#24 |
Awesone thanks for that, I am contemplating different seats also so I may end up the same direction you are. Keep us posted.
#25 |
Picked up the seats yesterday and made sure my co-pilot is going to fit in the seat. HaHa. My son is not old enough yet but when he is it's going to be fun.
