Old 03-06-2012, 05:04 PM   #1
BluTooth
57 Chevy Cab Frame Mount help
I ordered a cab frame mounting kit from LMC truck but not sure how the parts go back on the truck. So I don't have to do it over, can someone describe or draw how the parts go and which ones go front or back.
thanks,
BluTooth is offline   Reply With Quote
Old 03-06-2012, 06:32 PM   #2
Kim57
Kim57's Avatar
Re: 57 Chevy Cab Frame Mount help
I'll do my beat to explain it.
The thick rubber bushings are for the rear mounts and the thin "U" bushings are for the front.
The rectangular one goes between the cab and frame and the round one goes under the frame between the washer and frame.
Here's a pic from the service manual. It's kinda hard to see but helps.
"A" is the front mount and "B" is the rear.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-06-2012, 06:40 PM   #3
BluTooth
thanks, one more question, on the thicker rear cushion there is a smaller metal sleeve in the middle, is this oriented up towards the cab or down towards the frame.
Old 03-06-2012, 06:57 PM   #4
BluTooth
like this for the rear
Old 03-06-2012, 07:02 PM   #5
BluTooth
and this for the front
Old 03-06-2012, 07:05 PM   #6
Kim57
Kim57's Avatar
I would do them how you have the in the illustrations.
Kim
My build thread
Old 03-06-2012, 07:09 PM   #7
BluTooth
On the front I moved the rubber shims so there would be a cushion between the cab and frame.
Old 03-06-2012, 07:40 PM   #8
Kim57
Kim57's Avatar
Yes, I didn't notice that in your first pic.
Kim
My build thread
Old 03-07-2012, 07:41 AM   #9
fabguy
Elev8r Man
fabguy's Avatar
On post #4 ( rear cab mounts), don't the bolt go up and thread into the factory caged nuts? That's how my 58 is. Or do they send nuts to bolt it down?
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 03-07-2012, 10:09 AM   #10
Kim57
Kim57's Avatar
They supply nuts. I've had two different cabs, a 55 and a 57 and neither had caged nuts for the rear mounts.
Kim
My build thread
Old 03-07-2012, 02:42 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
By now the caged nuts most likely will have broken on most of these trucks so they supply nuts to bolt the cab down.
I just removed a 58 cab at the wreaking yard and of course the caged nut spun and broke the cage loose, had to use a vice grip to hold it.
G&R's57GMC is offline   Reply With Quote
Old 03-07-2012, 04:43 PM   #12
OrrieG
OrrieG's Avatar
On my 59 the front did not have any cushion (the think anti squeak piece was gone) and the cab had never been off the frame. I have assumed that it was to keep the cab, fenders and hood in alignment with the rear rubber providing some cushioning. Here is what the FAM shows.
OrrieG is offline   Reply With Quote
