03-09-2012, 12:18 AM | #1 |
3/4 ton swap 14 bolt Parking brake
Ok so I am just about finished with an axle swap to a 3/4 ton 14 bolt FF and gm 10 bolt up front.
How the heck do i make the parking brake cables work? I didn't convert it to disk brakes. I just want to use the normal parking brakes on the 14 bolt. It doesn't look like it's gonna be the right connections/ brackets/ length........ I don't know exactly what to do. How can I get my parking brake back without going to a line lock or transfer case ebrake? I just want to use the normal existing ones! |
03-09-2012, 02:33 PM | #2 |
New Member
Re: 3/4 ton swap 14 bolt Parking brake
Here's how I did mine. Look on page 2, post #45.
http://67-72chevytrucks.com/vboard/s...=413741&page=2 |
03-10-2012, 08:07 PM | #3 |
On my SF 9.5 swap I pulled the OEM Suburban cables off and re-used my original 12 bolt ones.
Tags |
14 bolt parking brake, e-brake, ebrake, parking brake |
