Old 05-04-2003, 04:22 AM   #1
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
WTB Big block motor mounts
Anyone have any BB mounts for sale?
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 05-04-2003, 11:39 AM   #2
Desert Rat
Desert Rat's Avatar
are you looking for the towers themselves?I have them,what years 68-71 or 72?
Desert Rat is offline   Reply With Quote
Old 05-04-2003, 02:19 PM   #3
cnshoot
cnshoot's Avatar
there is a set of mounts on ebay right now i can see where i have them saved at and i would be interested in towers
cnshoot is offline   Reply With Quote
Old 05-04-2003, 02:21 PM   #4
baggedblaz
chevy wrench you have mail..........
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
Old 05-05-2003, 12:21 AM   #5
Chevy Wrench
former desert rat
Well, what I am looking for are the towers. I am installing a big block into my 67. Dont know what exactly I need. This is my first time building this year of truck, so Im not sure on what I need. I guess the mounts on the motor and the towers on the frame. Any help????
Old 05-05-2003, 12:24 AM   #6
baggedblaz
chevy wrench check your pm box and call me, i have what you need and i'm in ut?
'71 2wd blazer
Old 05-05-2003, 12:29 AM   #7
cnshoot
cnshoot's Avatar
I would also like to know what i would need im sure of most of it but, there may be something just send me a copy of stuff that i would need for a 2wd blazer thanks baggedblaz and if you take care of chevy wrench let me know desert rat would like your towers ans mine would be a 72
Old 05-05-2003, 01:34 AM   #8
Chevy Wrench
former desert rat
Thanks Bagged, I will call you tomorrow.
Old 05-05-2003, 10:07 AM   #9
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Get the 72 stands, skip the 67-71 stands if you can. My .02
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-06-2003, 12:39 AM   #10
cnshoot
cnshoot's Avatar
Thanks for all the help. Deseartrat if you have some 72 towers i would sure like some
Old 05-07-2003, 07:40 PM   #11
baggedblaz
cnshoot all you really need to do a big block transplant is the same as the truck.
most important is the towers they sit different than the small block.
but you do need all the engine accesories and larger radiator.
chevy wrench i'll try to call you back tonight ?
'71 2wd blazer
Old 05-07-2003, 07:42 PM   #12
baggedblaz
oh yeah some people like to move the engine/rtans forward for valve cover to heater box clearance as well as firewall clearance..
good luck
'71 2wd blazer
Old 05-07-2003, 10:49 PM   #13
Desert Rat
Desert Rat's Avatar
BB Swap in a '67 you need
BB PS Pump and Brackets,Pulleys,Alt Brackets,Motor Mount Towers,fan shroud is different,the bracket on the frame for the shift linkage is different.but you can use SB and relocate.67 frames horns are fatter so you need to trim for towers to bolt in,put in the foward holes,your tranny crossmember needs to be moved(front holes line up on 67)others need to be drilled.Driveshaft will need to be shortened.if you have a AC truck your radiator should be sufficent-atleast mine is and it gets 110+ here.Its a easy swap,i have 2-67 frames here sitting under trucks i converted.also you dont have to use the factory Big Block stuff unless you want it to look like a factory 68-72 BB truck,you can use late model 73 up truck,69 up car BB brackets they are alot cheaper,it will just throw your alt on pass side,if you have AC on the driver side.
