Old 03-15-2012, 11:12 PM   #1
souza777
souza777's Avatar
what steps? check list?
hey I was looking to see if anybody has a checklist or sequence in what order to put my engine back together? I inherited a 78 square with just the motor and tranny in the truck everything else is in the bed. So do I start putting intake manifold then carb or exhaust or do I hook up carb 1st then disturbator.........
etc etc etc????
thanks for any help!!!
souza777 is offline   Reply With Quote
Old 03-16-2012, 10:16 AM   #2
UPNADM
UPNADM's Avatar
Re: what steps? check list?
Is the engine mostly together? Do you just have to put the intake manifold on? I think you need to expand on exactly what you need to do.
Lots of help available I am sure with more info.
UPNADM is offline   Reply With Quote
Old 03-16-2012, 01:27 PM   #3
souza777
souza777's Avatar
Talking Re: what steps? check list?
Ya I was thinking that! So I decided to take a few pics of what I got! I pretty much have everything laid out in the garage but just didnt want to go over and grab something and put it on, if something should of went on before that......???? does that make sense?
Old 03-16-2012, 01:34 PM   #4
Dieselholic92
Dieselholic92's Avatar
Put the balancer on with the pulley and water pump, and exhaust manifolds. Then put the carb on, put the thermostat and housing on. Prime the oil pump. Then make sure the engine is at top dead center on cylinder #1, and drop the distributor in making sure the rotor is facing the front of the engine. then you can turn it over and set the valve lash if you need to. Then do your plugs and wires, and fuel pump, valve covers, and the rest of the accessories
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 03-17-2012, 01:03 AM   #5
souza777
souza777's Avatar
Thanks!!!! That helps out alot!
