Fabricate till you "puke"
Some stuff will really whizz you off
I dont guess it was too bad, busting the ex manifolds off my parts truck(next plant for my 69)....I only have 1 broken bolt in the head. The damn thing had to break about 1/16" below the surface tho.... Now I have welded a nut /washer to the stud sticking out, many times (mostly iron heads or steel to steel app). What is the best way to deal with this "fun"? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: Nov 2004
Re: Some stuff will really whizz you off
Damn good question. The bolt closest to the DS firewall recently popped off on mine (5.3L). Same thing, right at the head surface. My neighbor had a local shop do his on is 6.0L, same bolt and they charged $250. Think I'm just going to take mine in.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Gearhead
Im guessing that this isnt in a location you can drill/tap or ez-out the broken stud then?? If so, I guess my next move might be to pull the head and try to remove the stud on the bench by whatever means necessary?
Sorry Im not much help, not sure what else to suggest...
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#4 | |
I have replaced the bolts on my '04 Tahoe 5.3L & the 6.0L in my dad's '04 2500HD. There were bolts on both that required a drill & ez-out and both had one up against the firewall (passenger side on the Tahoe & driver side on the 2500HD).
The bolts shouldn't be in there too tight. One of the ones in the center on the 2500HD started backing out as soon as I put the large reverse fluted drill bit into it. I started small with a 3/32" drill bit and worked up to a 3/16" reverse fluted bit. Those that still required the ez-out, I just used my small 4-point ez-out. You want to avoid the ones that are spiraled as they can tighten the bolt to the sides of the threaded hole. Get the ones that have straight 'teeth' along the edge to limit the amount of expansion in the bolt. All in all, I had to drill & ez-out 6 bolts total. The 2500HD had 8 bolts broken off, 5 of which were broken off flush or actually recessed in from the gasket surface! My Tahoe only had 3 broken off & 2 of them just had the heads snap off.
-'70 Chevelle Malibu - 350/TH350 - Torn apart -'74 K5 Blazer - 350/TH350/NP203 - 3"BL w/ 33x12.5 BFG - Too fun to tear apart -'04 Tahoe Z71 - 5.3L/4L60E/NP243 - DD CLICK FOR SIG IMAGE |
Gearhead
Well thats a lot easire to do on an engine stand then!
I agree with Swartlkk, do what he said! ![]()
This is DEFINITELY something that is easier on an engine stand. It still isn't impossible to do correctly with the engine installed, even with the rear most bolts. You just have to either get creative or get the right tools. I ended up borrowing a right-angle air drill from work to do the passenger rear bolt on my Tahoe. It was the only way to get at it straight on.
Thanks a bunch for all the input guys
I would drill it out & Helicoil it, The size is 8mm x 1.25. Center punch it first, Start with a small bit & gradually increase size of the bit.
I have done as clinebarger said, to drill out and gradually get larger with the bits, but I have gotten lucky numerous times that once the walls of the broken off bolt get thin and the heat generated from the drilling, whats left of the bolt will actually spin out using a pick, leaving the original threads fine to use again. NOT a gauranteed result however lol.
Here is a picture of the ez-out I used for both engines:
![]() And the bolt extractor set I used for those that only snapped off at the head of the bolt: ![]() ![]() The ez-out was from NAPA and the bolt extractor set was Craftsman. If you have broken exhaust manifold bolts, don't let them go too long or you could end up replacing the exhaust manifold. The 6.0L passenger side manifold had been loose for quite some time. The additional movement & vibration cracked the manifold: ![]() ![]()
-'70 Chevelle Malibu - 350/TH350 - Torn apart -'74 K5 Blazer - 350/TH350/NP203 - 3"BL w/ 33x12.5 BFG - Too fun to tear apart -'04 Tahoe Z71 - 5.3L/4L60E/NP243 - DD CLICK FOR SIG IMAGE Last edited by swartlkk; 03-23-2012 at 08:22 PM. |
Dont work to hard drillin it out till you try to weld it. If you are descent with a mig just use a nut and fill the hole. The weld will not stick to the aluminum and the heat will loosen up the loctite. The bolt will spin right out. I have drilled out many ex manifold bolts and they are almost always the rear bolt on the head. I have no welding skills so my coworker buddy does the welding for me. If he is not around I have to drill and easyout. It will take you 5 minutes tops with the welder.
#13 |
Done deal! I opted to drill it....all the original threads are pretty much intact. The first 1/4 " in is a tick loose, but all good after that. The threads go about 1 " deep, so I doubt there will be an issue? thanks to all the guys, crazyL
#14 |
I was able to weld/nut the driver's rear bolt out and it was broken 1/16" below flush. Royal pain and took many tries but it can be done in place.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
#15 |
Looks like a good "save"
