03-24-2012, 11:14 AM | #1 |
two inch drop
what is the best way to do so? i am using 15 inch wheels.
2 inch drop blocks in rear? cpp i found front 2 inch drop springs on craigslist for 100 bucks |
03-24-2012, 11:18 AM | #2 |
Re: two inch drop
That isn't a bad way to go. Both are easy to install. Be warned that there may be a scrubbing problem if you have a flat tire on the rear. The u-bolt will extend below the lower portion of the wheel and dig into the pavement. Although rare, it could happen.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
03-24-2012, 11:26 AM | #3 |
Re: two inch drop
thanks for the tip. i was wondering why it wasn't recommended
03-24-2012, 11:02 PM | #4 |
Re: two inch drop
Or is there a better way to drop? I want to improve handling without spending a ton. Allready have front and rear sway bars
Posted via Mobile Device |
03-24-2012, 11:17 PM | #5 | ||
"I ain't nobody, dork."
Re: two inch drop
Get the proper drop springs front and rear.
You can go cheap... but it's just easier to spend a little more cash and do it right. Springs can be heated. I've done it many times. But am not going to go into hpw to do it. Because it needs to be done a certain way to be done safely. A lot of cats won't heat springs. But... it's up to you. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-24-2012, 11:21 PM | #6 |
Re: two inch drop
Oh I will be installing parts. Not cutting or heating. I thought I read a while back that it was best to use a drop block in rear. A 3/5 drop spring would be pretty neat looking. I drag race the truck too. So not sure if I want to get crazy with the drop.
03-24-2012, 11:41 PM | #7 | ||
Re: two inch drop
New springs all the way then.
Gary
03-25-2012, 09:32 AM | #8 |
Re: two inch drop
Anyone have pics of a 2/2 or a 3/5?
03-25-2012, 01:32 PM | #9 |
Re: two inch drop
What about using dropped spindles?
I have basically the same situation. I do not want to change my wheels, running 15x10's all the way around, but want to use a 2.5/4 drop. Thanks, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
03-25-2012, 01:45 PM | #10 | |
Re: two inch drop
03-25-2012, 02:20 PM | #11 |
Re: two inch drop
3/5 (3"springs/2" blocks) using 255/60 and 255/70s. Because of the staggered tire sizes it should come down another inch in the front.
03-25-2012, 02:34 PM | #12 |
Re: two inch drop
mines not 100% complete, but mines a 2/4 static with 2 drop springs in the front, 3 in springs with a 1 in block in the rear.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
03-26-2012, 05:31 PM | #13 |
Happy to be here
Re: two inch drop
I thought you were going to leave it stock and add bags in the rear?
