Old 03-28-2012, 02:16 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
For those that have used the 87 Spectra tank/sending unit
I have everything installed and now I need to wire it up. I have the 87 fuel tank and sending unit with the EP381 fuel pump. I would like to get my fuel gauge working again so I need to know how to hook it all up. If you have a wiring diagram I would appreciate it.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-29-2012, 02:24 PM   #2
Jonboy
Slots go on anything!
Re: For those that have used the 87 Spectra tank/sending unit
IIRC, the pink wire goes to the gauge, the other (tan?) wire is power. The pump will be grounded at teh tank, through the sender.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-29-2012, 08:12 PM   #3
OldCreek
OldCreek's Avatar
iirc, gray to fuel pump power, purple to gauge, ground to ground.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-30-2012, 10:42 AM   #4
Jonboy
It is exactly the reverse of whet you would think; the lighter color is the gauge. The dual tank senders are differenct colors on each side, too.
Old 05-08-2012, 12:32 PM   #5
softballnrd27
I am bringing this up again bc I am about to wire up my fuel pump and there are 2 different ways that came up.
Is it dark to power or light to power?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 05-08-2012, 12:39 PM   #6
Jonboy
I remember it is opposite of what you would expect. The A/M harness I used has a grey wire out to fuel pump power.
Old 05-08-2012, 10:32 PM   #7
softballnrd27
Just to make sure that we are talking about the same thing, I have the spectre sending unit that has 3 wires coming out, 1 single wire for the ground and a 2 wire plug. I need to know which wire I supply the power from the relay to. I might have read your post wrong but it sounds like you are talking about the stock truck wiring.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 05-11-2012, 01:35 PM   #8
OldCreek
OldCreek's Avatar
grey is power. purple is gauge.
hook up the purple. plug and unplug it and watch your gauge to confirm it is gauge.
Old 05-11-2012, 02:07 PM   #9
ls1nova71
ls1nova71's Avatar
X2 this is correct
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-11-2012, 10:17 PM   #10
softballnrd27
Ok thanks guys. One more thing I plan to check off my list this weekend
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
