Old 05-06-2003, 08:47 AM   #1
Blue'66
Wanted: Air Cleaner for '69 C-10, 307 2bbl
Looking for a original air cleaner for a '69 C-10 with a 307 and 2 bbl carb. Need not be clean or perfect, just usable.
'48 1/2 ton 3100
'55 1 1/2 ton 4400
'59 Willy's CJ-5
'65 3/4 ton 4x4
'70 C-10
All drivers, no show trucks.
Blue'66 is offline   Reply With Quote
Old 05-06-2003, 10:12 AM   #2
billsbowtie
billsbowtie's Avatar
sent you a pm
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 05-06-2003, 11:07 AM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I have one... will include top the base and the riser for 20 plus shipping.
I assumed you knew the carb has a stud that comes out and you can attach it with a wing nut on the top.... if the nuts there its yours also
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 05-06-2003, 01:09 PM   #4
COBALT
COBALT's Avatar
I have a snorkel style off of a 327 that fits a Rochester 2gv. It has the tube in the bottom that runs to the valve cover using a breather. The top has a rubber seal, and I have a 2gv spacer (excellent condition), stud, and wing nut that fits it. The only problem is the paint is flaking off a bit (black), and somebody drilled a couple of holes in the lower part to try and increase air flow.
$15 + shipping for the air cleaner.
$25 + shipping for the air cleaner + spacer, stud & wing nut
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
