Old 04-05-2012, 10:32 PM   #1
HEISEL
HEISEL's Avatar
98 Vortec 350. Fuel pump help!
Hi all, so I have a 98 Vortec 350 that a had rebuilt back to stock. Except it has a edelbrock carb intake. Because im going that way. So my plan was to put a mechanical fuel pump on it because it has provisions for one. My question is can I do this? I was told that I needed a special pump rod for this? Because its a roller cam I guess? O ya it's going in my 72 k10 swb. Is this true? Any suggestions? Thanks.
1972 k/10 4x4 swb
2011 camaro SS/RS M6
HEISEL is offline   Reply With Quote
Old 04-06-2012, 12:49 PM   #2
61K10
61K10's Avatar
Re: 98 Vortec 350. Fuel pump help!
you can get one from jegs or summit that has a bronze tip $21 or a roller tip $100+ roller cams are steel not iron and i guess the lobes aren't heat treated. somebody here knows the story. i ran a bronze tip one with a roller years ago. does chevy make a stock one?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-07-2012, 09:27 PM   #3
1972CST
1972CST's Avatar
Some roller cams don't have a lobe for mech. fuel pump.
1972CST is offline   Reply With Quote
Old 04-07-2012, 09:58 PM   #4
clinebarger
Ive never seen a production 98 vortec block have the hole for the pump rod.
Like 1972CST said the Factory Production cam WILL NOT have the lobe
clinebarger is offline   Reply With Quote
Old 04-07-2012, 11:14 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
The mount is still cast on the block but there is no hole for the pump push rod. If you are rebuilding a block the hole can be drilled but not on a used install because you risk metal shavings getting into the block. I think that factory cam does not have a lobe for the mech pump. The easiest way would be to go to the parts store and get a universal electronic fuel pump for a carb. like this from autozone.
http://www.autozone.com/autozone/par...1_173883_4967_
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-08-2012, 09:13 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
If you go with an electric fuel pump it is a good idea to also put a fuel pressure regulator in since the Edelbrock carbs like a constant pressure, I can not remember the exact number but I think it is 5 pounds.
Also the fuel pump should be mounted as close to the tank as possible.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-09-2012, 12:19 AM   #7
rayfinseats
Go with an electric pump. You can get a cheap one since you only need 5-6 pounds of pressure. It helps with vapor lock if running high compression or headers. Easier to replace too. I had four different kinds of pumps on my 68 camaro before I went electric.
rayfinseats is offline   Reply With Quote
350, 5.7, fuel pump, vortec
